m3photo
Hello playmates! Just thought I'd copy and paste this message which I wrote in answer to Rawfa's plea on the Small Sensor Cameras section on GetDpi for any information as to buying/using/posting with the new Canons - G11 and s90.
OK, I've decided on an s90. Had the s50 (nice flip open, reminded me of my Olympus Mju), then G6 (lovely lens), then G9 (good all-rounder) BUT ...
s90; What a sensor! It's a perfect little always-with-you camera that has a charming double personality: a good quality RAW shooter that delivers files you can get lots from and an Auto everything jpeg party shooter that even takes ambient light into consideration when taking indoor flash snaps. Talking of personality, one funny trait is the fact that said RAW files seem to come out with more sharpening than the jpegs, go figure.
Anyway, the man said posting, so I thought coming from the m4/3rds crowd I'd show you a couple of side-by-sides with a G1. All shots 16bit Raws just tapping the Auto button in Camera RAW then downsampled to jpegs for posting. I found that the s90's responded well to the Shadow-Highlight command in Photoshop at 100% Highlight/50% Tonal Width and the bottom slider I always leave on at the maximum 2500 anyway; no halos this way. No sharpening - as stated before, the s90's don't need them and I thought it fairer not to touch the G1's.
First the 28mm equivalent pair. Both at f/3.5 as that's the maximum aperture on the G1's kit zoom and although the s90 boasts f/2 at 28mm equivalent it's only for emergencies, f/2:8 is fine but for a bit more dynamic range I'd say f/4's the sweet spot (naturally at this sensor size, depth of field is the same anywhere you set the aperture on shots like this).
G1:
s90:
This second pair is at 90mm equivalent on the G1 (max zoom) and 105mm equivalent on the s90 (max zoom) both widest aperture here, i.e. f/5.6 on the G1 and f/4.9 on the s90.
G1:
s90:
Have fun (resisting temptation, that is!)
G1:
s90:
G1:
s90:
