Problems with Wide Lenses - Summary
henningw
There are lenses for 1.2-1.3" CCD sensors, but they cost between $2000 and $5000, the ones I've seen. That one above is probably well over $2000.
And it's HUGE and heavy. MTF looks good, but over 20% distortion! No thanks.
Henning
S
seb33
WIDE SHARP CHEAP and FAST C-mount lens on GH2 !!! (Pentax 6mm 1:1.2 with crop mode 1:1)
http://vimeo.com/20766631
NEW : QUICK TEST between this lens and the Lumix pancake 14mm 1:2.5 here :
vimeo.com/​20788176
AT LEAST I've found the PERFECT WIDE SHARP and CHEAP lens for the GH2 !!! It's a C-mount Pentax/Cosmicar 6mm 1:1.2 lens I've bought 9.99€ (12.50$) on Ebay !
The rear barrel had to be modified for 20€ (watch pictures below) to fit on the C-mount to micro 4/3 adapter (Kipon).
This 6mm focal lenght on the GH2 gives a huge vignetting on micro 4/3 sensor, but thanks to the new crop 1:1 GH2 function, the vignetting is disappearing completely !
This 6mm lens with the crop function gives nearly the same frame (same width but less height) than on the Lumix 14mm 1:2.5, but much much more faster.
It's a sharp lens, even with the crop. In 24X36 eq. it's a 30mm.
This lens is incredible for GH2, there is no other competition for such a fast lens !
In this movie you will watch daylight tests (always @ 1:1.2, 1/50 shutter speed, 160 asa) with a 22€ Polaroid 43mm variable ND filter and a 40.5 to 43mm step-up ring, there's my girlfriend preparing her new collection for children "Pitchoovintage".
Then you will watch night test, from 160 to 3200 asa, always @ 1:1.2 and 1/50 shutter speed.
GH2 24P
Crop mode 1:1
No CC
from 1/25 to 1/50 shutter speed
edited on Adobe Premiere CS5
music : Elusive "Intro" + "writing on the wall" from "Pressure Drop" EP
duration : 4mn49sec
HERE IS AN INTERESTING LINK FOR HOMEMADE C-MOUNT MACHINING :
cjeastwd.blogspot.com/​2009/​06/​adapting-lens-to-fit-mount.html
And a post (in french) from my friend Christophe about the crop :
christophemilet.com/​?p=1589
