S
seb33
http://vimeo.com/14578447
On october the 4th, 2009, I have filmed some material with a 30$ C-mount Cosmicar 25mm 1.8, a very small and light lens in L'herbe, a small fishermen port near Bordeaux, France. I always openned it at 1:1.8 for its particular circular bokeh, it reminds me pictures from my Lomo Olga. It's a lens for security camera.
Then almost 1 year later, on august the 8th, 2010, I went back to l'Herbe, but with my new 30$ Fujian CCTV C-mount 35mm 1.7, no vignetting there, but you have a "tilt shift effect" because of the lens' poor quality
Between those two dates, the GH1 hacked firmware have appeared.
This is a comparison between those two cheap CCTV lenses, and the Panasonic / hacked firmware, in the same place, with my same (oldest daughter.
1- GH1 720P PAL (Panasonic Firmware)
30$ C-mount Computar TV lens 25mm always @ 1:1.8 for its particular circular bokey
400 to 100 asa, shutter from 100 to 4000 to keep it wide open
2- GH1 720P NTSC (hacked firmware)
Fujian CCTV C-mount 35mm always @ 1:1.7 for its particular tilt shift effect
Edited on Premiere CS5
No color correction
You can watch the original 2009 Cosmicar movie here :
vimeo.com/6898873
and another Fujian/hacked movies here:
vimeo.com/13797794
vimeo.com/13910873
Hacked firmware from Tester13
"AVCHD STABLE POUR 720P
Selon jobless
Video bitrate adjustment - 38000000
Overall bitrate adjustment - 40000000
Limiting bitrate adjustment - 42000000"
Since I've hacked my GH1, two mains problems have appeared :
1- I can't edit anymore on Premiere CS5 (on a Mac Book Pro unibody end 2008 with 4 Go of RAM), there is too much bit rate for native editing, so I have to edit with FCP trough "Log and transfert" in Apple Pro Res
2- I can't shoot on 720P under 60 shutter speed because of awfull mud problems.... Wich is a problem when I want to have more light...
Duration : 2mn56sec
Music : The Velvet Underground "Sunday morning"
No color correction
vimeo.com/6898873
vimeo.com/13797794
vimeo.com/13910873
Selon jobless
Duration : 2mn56sec
