i didnt name the thing the author did, why get so hooked up on names and definitions, i just dont see the pointI am a little bit confused here. I tought that EV values are independent from sensor format; in fact if I take a picture in a sunny day with a D700 and an E5 both set at 100 ISO, I will get 1/125sec at f/8 for both as long as the lenses have the same equivalent focal lenght or angle of view (let's say a Nikkor 50mm and a PL 25mm). The only difference would be in the DOF which will be about twice for the E3+25mm. In terms of light we will get same EV for both (likely EV=13).
Form another perspective the amount of light hitting 4/3 sensor is going to be about 1/4 of the light hitting FF because 4/3 lens diaphram is set at 3,125mm diam. while FF diaphram diameter will be 6,25mm:
FF exposed area thru the lens = 30,7 mm2
4/3 exposed area thru the lens = 7,7 mm2.
On the other end the 4/3 sensor has just about 1/4 the area of a FF sensor, thus the amount of light per unit area is the same, which justifies the equal settings for shooting under same conditions.
Really, the only difference remains DOF.
carlo
Thanks for that effort!I went for a walk today with both combos: D700+24-120VR and E5+12-60.
You can download the direct comparisons here for private use only (the "D700 vs E5" album):
http://gallery.me.com/nugat#gallery
These are big jpegs: 6-11MB. At around 2:1 compression they are visually lossless, full size, no crops. Only the "Palace" I bothered to compare here and include Oly raw (ORF) to jpeg developed in Oly Viewer, as well as the out of camera (OOC) E5 jpeg. I could not see any difference ( I did couple more comparisons for myself ), so then I used only LR3 Oly OOC jpegs and Nikon NEF to jpeg.
Olympus is here exactly what E5 offered in Superfine JPG out of camera (I also recorded orfs). To level the ground I processed Nikon raws (14 bit NEFs/d-lighting normal) in LR3 Adobe Preset , as the Nikon OOC JPGs are immediately worse than Olympus in resolution. Fortunately LR3 developer is pretty good and no work on color had to be done. But most of these NEFs required exposition corrections (highlights, black level). Olympus on the other hand nailed the expossition almost perfect all the time. Both E5 and D700 were in "P" and exposure was full frame/center weighed, focus with one central spot. VR/IS on. Both camera chose very similar EI values and ISO at/near the native 200 (full EXIF included, or click "i" for info).
I will save you the trouble and give my appraisal immediately this time.
Both combos cost near the same money, are very similar in many aspects (Oly a bit smaller) and deliver similar pictures near native ISO.
Except Oly does it out of camera as JPEG, and on Nikon NEFs one needs to do work to get close. Close, because Oly OOC JPG resolution is a tad better than NEFs developed at the preset sharpening of 25. Again, I had the weird phenomenon of some Oly pics' sharp lines aliasing on the one monitor with the bigger pixels (EIZO), to smooth out at 100% on iMac 27 inch (smaller display pixels). Sharp people make sharp pictures. Sorry, Olympus people do so.
PS.
I could get Olympus jpegs sharpness working on NEFs with NIK Output Sharpener. But NIK on Oly raw/tiff again increased the distance.
In one of the pictures NEF seemed cleaner in shadows, but more comparisons should be done on that.
PSPS
When I get the SHG glass will do the lest leg of comparisons.
Why should I keep the same DOF? Or to be exact the same CoC (circle of confusion) of the final viewed image ?I would keep always aperture doubled on D700 - in order to keep the same DOF.
Are you watching them from the downloaded files?Thanks for that effort!
While in general I like the E5 images far better, I have a question what happened to the images "lake" and "leaves" - in these 2 images the D700 shot is tack sharp and good resolution, the E5 shots are either not sharp or do not get the resolution of the D700.
I think something went wrong while converting?
Peter
Otherwise - we can discuss apart from bodies - what one prefers - less or more DOF, 43 sensor or FF sensor.Why should I keep the same DOF?
Let more people share that approach!In the end what counts for me, is the overall picture quality as seen by my friends, family, myself and pundits--in that sequence.
I downloaded them and imported in LR3 - strange .....Are you watching them from the downloaded files?
Do not pass judgement from the gallery viewer frames directly, there is something indeed strange how they are presented here. Some are converted by the gallery display software with less resolution (limited to 1280 anyway). Do not forget your browser algorithms. Only download and good jpeg viewer! Sorry for the size.
HI PeterThanks for that effort!
Peter
I have some mixed feelings too. It all depends if I will go with just one system in the future (sell Hssselblad and stay maybe with Nikon - D4X as my high resolution camera) or if I keep the Hasselblad for high resolution and great color and go for a smaller solution with less resolution - could then be 43 or M43, but also some other D800 to come.HI Peter
I think the E5 looks great . . . . . but you seem to have written off Sony on the basis of the quality of the A900 and the autofocus speed. . . . . . and now you're considering ditching the Nikon D700 in favour of the E5.
I find the combination of these concepts to be completely odd - it doesn't seem to give any indication of your uses for the camera.
I think all three cameras have real advantages:
E5 - nice colour, fine zoom lenses, weather-sealing
D700 - fast autofocus - grand high ISO
A900 - great colour - splendid detail in 25mp files
If you want the detail AND the autofocus and you like the Nikon colour (all of which you've said). Then what's wrong with the D3x?
If you want the detail and you don't need the autofocus, then what's wrong with the A900?
If you want the High ISO and you don't want the detail, then what's wrong with the D700
If you want something smaller with decent quality, then the E5 isn't it either (you could think of Pentax or Sony, or even a Nikon D7000)
The only reason for wanting the E5 (that I can see) is that you don't care about the detail or the high ISO or the autofocus . . but you do like the Olympus colour and the weathersealing.
I'm very confused!
Fair enough - but what's wrong with the A900, which is half the size and half the price (and I'd argue a nice camera to use, with better lenses, less PP to do and just as good results - unless you want the high ISO).I have some mixed feelings too. It all depends if I will go with just one system in the future (sell Hssselblad and stay maybe with Nikon - D4X as my high resolution camera) or if I keep the Hasselblad for high resolution and great color and go for a smaller solution with less resolution - could then be 43 or M43, but also some other D800 to come.
I actually would have gone the D3X path, if this camera would not be at its price level and be already out there for 2 years, so replacement should show up pretty soon.
I did have an E3, and I did like it, but it wasn't much smaller than the A900, the image quality was so much less good (really a different world).Why did you not go for the E3 or now E5?
Because I don't want a FF 12mp camera - for me the point of FF is to be able to have a lot of resolution, not just a big camera.Why did you not try Nikon D700 lately with new FW - I think colors are quite good?
Because I don't use C1 pro anymore, and because I've been been there with respect to Nikon cameras in the past, and I found that I needed to change colours with lots and lots of shots (especially in evening light). I never could manage a profile which dealt with all situations.Why not make a profile in C1 Pro, where you can almost tweak any color from any cam?
Well, I think the E5 looks fine if you already have or want the Olympus pro zoom lenses - but they're really big, and the E5 body is big as well. For me the attraction of 4/3 was the possibility of getting something small and tough and weather-sealed - For example the Olympus 90-250 weights 3 kg, I know it isn't quite a like for like comparison, but the Pentax 60-250 weights 1kg. I'm not criticising the reasons for it - just that I don't want a lens that big - not even if it's attached to a 25mp full frame sensor, but especially not if it's attached to a 12mp 43 sensor.I must say I find the E5 very appealing, but I do not like the direction Olympus is currently moving with 43 - think they have much more emphasis on M43. And I would have expected the 16MP sensor from the GH2 in the E5 ... maybe too much wishes!
HI GodfreyI've simplified already: I'm very happy with my lenses and my camera, and not really looking at anything else. I'm working on my photography now. ;-)
FWIW, the color advantage of the A900 isn't a matter of color profiling. Sony, in general, uses a less transparent color filter than most other DSLR makers, so, while this can cause more noise at higher ISO, it provides less metameric failure and better color separation. Essentially, this results in better resolution in greens and/or skin tones (ie: less mushy) than some DSLR brands. Because of this, the Sonys are well suited for landscape and portraiture.I have some mixed feelings too. It all depends if I will go with just one system in the future (sell Hssselblad and stay maybe with Nikon - D4X as my high resolution camera) or if I keep the Hasselblad for high resolution and great color and go for a smaller solution with less resolution - could then be 43 or M43, but also some other D800 to come.
I am genuinely interested to know more details about this. Could you help?Sony, in general, uses a less transparent color filter than most other DSLR makers, so, while this can cause more noise at higher ISO, it provides less metameric failure and better color separation.
And I don't know why he wants to replace his Hasselblad at all.... I didn't see why either camera fitted either bill! ...
Sure. It's a long, winding road, and I've really only scratched the surface. Essentially, though, most DSLR makers have been making their CFA filters more transparent over time, in order for more light to reach the sensor, and this requires less amplification gain. Thus, they sacrifice low ISO color performance for better high ISO. This is one of the reasons why Sony cameras in the past have had slight high ISO disadvantages when compared to cameras of other makes that have Sony sensors. Canon and Sony seem to be on the opposite of the end of the spectrum in this regard, with other makes falling somewhere in between (generally.)I am genuinely interested to know more details about this. Could you help?
Thank you DouglasFWIW, the color advantage of the A900 isn't a matter of color profiling. Sony, in general, uses a less transparent color filter than most other DSLR makers, so, while this can cause more noise at higher ISO, it provides less metameric failure and better color separation. Essentially, this results in better resolution in greens and/or skin tones (ie: less mushy) than some DSLR brands. Because of this, the Sonys are well suited for landscape and portraiture.
