Link should work now
This link is open:
http://gallery.me.com/nugat#100084
 My test chart is just a page torn out of a photo magazine. Obviously because of the small size it must be shot from close up. Hence the difference from the clean dpreview chart look, which must be big and shot from far. But the trumpet lines coalesce just as fine at resolution limit.
As a rule of thumb, MTF50 is where they are still seen very clearly/contrasty as separate, MTF30 where you manage to  see them still separated, MTF10 they just mix together (although it's possible to count them--barely).
It looks DPReview gives MTF 30 figures.
DPReview gives the resolution of D3x here:
http://www.dpreview.com/reviews/nikond3x/page32.asp
Note "prime lens was used" at f9 (presumably the best lens).
Frankly, I don't get what they mean with "extinction resolution", I see only grey there.
My test was gun'n'run: the "resolution chart" in available light and E5+zuiko on tripod. The Zuiko is a zoom of course, this particular shot at 14mm/f4.
But frankly , The Zuiko is very, very consistent and it looks the same at all f-lengths and f-stops until diffraction kicks in after f11.
Can't wait for DPreview to show their resolution tests for proper comparison.
