Olympus stabilization and Voigtlander 25mm f 0.95
Martin S
I noticed the need (for me) for an in body stabilization body to best use the Voigtlander wide open in low light situations. Any suggestions??? The G1 is fine, but, of course, lacks any stabilization.
I guess an Olympus body is the only answer???
Recommendations???
Thanks.
Martin
Jonas
Recommendations???
If you found you can't live without IBIS Olympus is the only option. But who can tell what model is the right one for you?
I need a viewfinder. A super fast lens needs short shutter times. EP2.
/Jonas
PeterB666
The combo works fine. I use an Olympus E-P1 with the Voigtlander 25mm lens. I would look at the E-P2 and optional viewfinder rather than the E-PL1 as you will use shutter speeds over 1/2000s.
iskaII
e-p2 + VF2 + VC 25mm f0.95 = almost perfect perfect match for me (feels heavier than M8 plus 50 cron).
