M4/3 and flash photography?
MRfanny
Hi everyone,
I am considering trying some flash portraiture/model photography with my gh1. I think it would help a lot with dynamic poses. From my limited understanding of everything in general, the gh1 isn't well suited with syncing with flashes is that correct?
Just after some valuable forum input on the matter, is it worth it, what flash is recommended, and anything else i should take into consideration. What does everyone think of the Olympus FL-36 or FL-36R? Ideally I'd like to invest in a fairly futureproof flash if i decide to move on to another format, full frame maybe.
Bottom line i guess is am i gonna be wasting my time and money with this new interest?
Cheers.
MRfanny
Thank you very much Kevin. Quite informative beginner video and definitely bookmarked.
One thing to add is i come from a video hobbyist background so i have a number of led lights that i use to light up subjects. I think this method is called using hot lights where the light is constantly on? How normal is it within the industry for people to use hot lights instead of flashes for lighting models?
JMaher
While the 36 and 36r are very nice flash units and will sync with both Olympus and Panasonic they are by no means universal and won't translate well to the world of full frame. The Strobist recommendation was a great one to get you started. Each manufacturer tends to use it's own dedicated units for TTL flash and if you move into the wonderful world of manual flash you can pretty much mix and match with greater control but a much steeper learning curve.
Jim
photoSmart42
That depends on what you mean when you say it's not suited with syncing with flashes. I've used my GH1 with a variety of remote flash triggers (optical and wireless), with up to three off-camera flash units (that's all I have). I've also used it with corded off-camera flash units. Surely the flash sync speed of 1/160 isn't ideal, and I wish it would have been more like 1/250, but other than that I don't know what else the system could do to be suited to flash photography. Can you clarify your concern?
Godfrey
A friend has been concentrating exclusively on model photography for the past year and some. His lighting kit is an Olympus FL50R, a couple of Vivitar 285s, a bevy of stands, scrims, gobos, diffusers, etc. He's been shooting exclusively with the Panasonic Lumix G cameras and turning out some superb work.
I don't know what would be limiting about a GH1 other than the 1/160 second flash sync with non-dedicated flash units. Used with dedicated flash units in FP mode, even that limitation goes away.
If you are dependent upon dedicated flash unit features, no matter what the brand, you'll need new ones if you change camera brands. If you base your flash techniques on manual control of the flash units, than all of them are future proof if they can be controlled on the flash. The Olympus FL36(R) and FL50(R) are fully dedicated for your Panasonic yet also have in-flash auto and manual settings controls.
MRfanny
Godfrey- does he happen to have a site with his work on it?
And thank you all for your inputs.
I guess my main concern was using/syncing flash with shutter speeds higher than 1/160 in general especially for those dynamic shots like twirling/jumping/hopping in the air, hair flicks, interactions with foreign objects/accessories (eg.bag/water). Even shots outdoors where you want to light subjects that are standing in front of the sun with shallow DOF etc.
I really don't know what dedicated flash features to look out for or need. As much control of light as possible is what I am after so I assume that means manual controls. What will i miss out on or gain if i don't get a panasonic dedicated flash(Vivitar 285)? I really do need to school myself in flashes =) By the looks of it, the Olympus FL's seems to be the go? Is it just a simple case that M4/3 is just not the right tool to use for dynamic flash shots but fine for normal shots?
MRfanny
After abit more reading, I now understand.
So the FP modes on the Olympus's should work on the GH1, allowing me to sync with shutter speeds up to 1/4000th correct? I think I may just splurge and get the 50R knowing i can use it off camera now and in future if I ever decide to move away from m4/3. Is this a good choice for a first ever flash purchase?
Godfrey
Last time I talked with my buddy, he said, "I really have to completely re-do my website. Everything there is too old and crappy, and I haven't posted any of the recent work... since 2009 ... !"
I don't think he's posted new stuff yet, although he does have some on modelmayhem.com and flickr. can't find his account name ... !
Nothing stops the Micro-FourThirds cameras from being as capable as any other camera when it comes to flash utilization. The only thing the Panasonic bodies are missing is wireless remote dedicated flash operation, and for most higher level use of flash, that's stuff is mostly useless anyway.
The Olympus FL50R is a very good flash unit, with excellent dedicated features as well as in-flash auto, remote and manual controls. It's built like a tank like all of Olympus pro-grade equipment. That and a good, long remote cable for your GH1 should net the power you need and all the features you'd want to get the flash off the camera. (and stands, etc). The Metz units are also good, but I prefer the Olympus ... better built, better documentation in my experience.
Note that Panasonic, Olympus and Canon dedicated flash cables share the same pinout. It's easier to find cables labeled for Canon than Olympus or Panasonic ... I've got one of these on order:
http://ocfgear.com/ettl-cord-extra-long/
Much more useful than the short coiled remote cords. For non-dedicated setups, there are a number of good RF flash triggers available at a range of pricing but then you lose the FP mode.
MRfanny
Thanks Godfrey, really interested in seeing your mates work so if you remember his username please share.
Now that's what I want to hear.
I'm glad you mentioned this, otherwise i probably would have started another thread asking why FP isn't working with the RF triggers(is this the case also for the higher end RF like the Pocket Wizards?).
Let's say I wanted to use 2 flashes in FP mode how do i wire that up? Is there an adapter that lets me plug the cords in series, ie camera to flash1 to flash2?
Edit: I found this informative pocket wizard clip for their solution to RF high sync on Canon and Nikons, unfortunately no signs for Olympus yet.
http://www.pocketwizard.com/inspirations/tutorials/pocketwizard_controltl_optimiz/
peterb
I've used the G1 with a wireless from B&H with good results. The flash is a Photogenic with a 3x3 softbox.
Godfrey
Hopefully, I'll see him later this weekend.
... I'm glad you mentioned this, otherwise i probably would have started another thread asking why FP isn't working with the RF triggers(is this the case also for the higher end RF like the Pocket Wizards?).
No one makes a RF dedicated setup for Olympus/Panasonic protocol at present, although a couple of folks have said they were considering it. If you were working with a Olympus body that supports the wireless protocol, you'd do multi-flash FP using the optical wireless capabilities.
I think Olympus makes (or made) a flash cable that would allow you to hook two together, perhaps Canon does, but since most of these companies are going wireless on their flash systems the number of cable accessories has been cut back.
I don't use FP very often, it cuts back power too much for most purposes. I just set up with a set of RF triggers and work with the 1/160 X sync limit. If I need to cut ISO, for daylight setups, I use a 6 or 8 stop ND filter.
