Page 20 of 56 FirstFirst ... 10 18 19 20 21 22 30 ... LastLast
Results 951 to 1,000 of 2765
Thread: Fun with the Olympus OMD
  1. #951
    Senior Member JMaher's Avatar
    Sarasota
    942
    16
    Re: Fun with the Olympus OMD
    The glow of tubes. Attended an audiophile meeting today. ISO 6400 - Lit primarily by the tubes themselves.
    Jim
  2. #952
    Senior Member Mike Woods's Avatar
    Bristol, UK
    1,473
    Mike
    http://mikewoods.zenfolio.com/
    Likes 9 Member(s) liked this post
  3. #953
    Ithaca, NY
    3,384
    A couple of shots taken today with the Contax G 45 f/2 on the OMD. Nice being able to hand hold at base ISO in dim lighting without having to resort to autoISO.
    Carl
    Gallery
  4. #954
    Senior Member etrigan63's Avatar
    Earth, Sol System (near Miami, FL)
    2,495
    21
    Fun with bulb exposure:
    Light Painting by Carlos Echenique, on Flickr
    Carlos Echenique | Carlos Echenique Photography |Olympus OM-D E-M1 MK II | Olympus Pen-F - M.Zuiko 17mm f/1.8, M.Zuiko 25mm f/1.8, M.Zuiko 45mm f/1.8, Rokinon 12mm f/2 NCS, M.Zuiko 75mm f/1.8, M.Zuiko 12-40mm f/2.8 PRO, M.Zuiko 40-150mm f/2.8 PRO
  5. #955
    Nov 2009
    Hawaii
    943
    16
    A series with the Contax 100-300mm. Most everything shot in the 250-275mm range at f/4.5.
    I am finding that in the 200-300mm range, the lowest shutter speed handheld for me is about 1/200 without getting microblur. So what is that?........about a two stop advantage with the IBIS? Whatever it is, it has made a sizable difference in the way I use this lens.
    R
  6. #956
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,728
    Hi Rich
    Sounds like my use of the R 80-200
    There's shots are lovely,especially like the horse. Excellent!
    Just this guy you know
  7. #957
    Ithaca, NY
    3,384
    One more from the local gorge walk. I liked the contrast between the sharp angles and lines in the gorge walls and smooth curves and surfaces in the stream bedrock. Contax G 45mm f/2 on OMD.
    Carl
    Gallery
    Likes 7 Member(s) liked this post
  8. #958
    Bristol, UK
    1,473
    A brief break in the weather this evening:
    Mike
  9. #959
    Aug 2010
    168
    I like that Mike, but what is the horizontal line running through the photo?
  10. #960
    Bristol, UK
    1,473
    Quote Originally Posted by Glenn View Post
    Thanks Glenn. Fortunately not a cracked sensor - simply a telegraph wire that I was too lazy to remove
    Mike
  11. #961
    Aug 2010
    168
    Quote Originally Posted by Mike Woods View Post
    Mike
    Ah, I thought I might have a cracked monitor!!
  12. #962
    jonoslack's Avatar
    11,728
    Love the church shot Mike - you're really making that camera sing!
    all the best
  13. #963
    Bristol, UK
    1,473
    all the best
    Thanks Jono, I'm really enjoying it. It would be even better if I could get to the bottom of my battery issues....140 shots max per charge on each of 2 x Oly batteries. I did read a report of a charger problem, so I'm hoping a new charger from my dealer will solve the problem.
    Best wishes
    Mike
  14. #964
    Knorp's Avatar
    3,529
    Hey Mike,
    Same here - after 150 shots or so the battery is depleted even with modest chimping.
    Somewhere Jono mentioned getting over 600 shots from one charge !
    Luckily I've got two batteries now, but still the yield per battery is poor.
    Where did you read about the possible charger problem ?
    Thanks and all the best.
    Bart ...
  15. #965
    jonoslack's Avatar
    11,728
    Quote Originally Posted by Knorp View Post
    Hey Mike,
    Hi Bart - and Mike as well.
    I've just been checking - I took it with one battery to the pink lady tractor run, and the first shot is 3308, the last shot is 3944 . . . sounds like 636 - but it hadn't run out - it went on charge then. Worth noting that a lot was shot with Leica R lenses, in fast batches of photos without too much chimping.
    Since then at Latitude festival I used it all weekend - I only shot around 300 shots, but the camera was on a lot of the time over 3 days and it was still showing full charge at the end.
    Something's wrong somewhere (let's hope it's the charger!) Just recently I actually got a 3rd party Expro charger because I couldn't get another Olympus battery - that charger seems to charge Olympus batteries quite okay.
    Mind you - 150 shots a day seems to me to be 50 too many (I plead guilty on numerous occasions!)
    All the best
  16. #966
    Bristol, UK
    1,473
    Hey Mike,
    Hi Bart, I did a search online and found someone on some vague forum with the same problem. He sent the camera back initially and Olympus could find nothing wrong with it. Then on a whim he tried another charger and it cured the problem.
    I've borrowed a generic charger from my dealer whilst mine is being exchanged. Interestingly, last night my battery died in-camera, but when I put it into the generic charger it showed an approx 50% charge, and was fully charged in less than an hour....
    I'll let you know how it goes, but so far I'm convinced it's the charger....famous last words!
    Mike
  17. #967
    Nov 2010
    NYC
    1,475
    4
    It's not art, but then the title of the forum is Fun with the Olympus OMD. Besides, this flower looks about the way I feel.
    Best,
    Matt
  18. #968
    Knorp's Avatar
    3,529
    Hi there Jono,
    using mainly R-lenses could very well explain the higher rate !
    After all there is no AF motor to engage and I was using the Panasonics 14-140 and 100-300 ...
    Makes perfectly sense to me.
    Now let's see what Mike can tell us about that charger report he mentioned.
    Oh - always good to have you around
    All the best.
    Bart ...
  19. #969
    Knorp's Avatar
    3,529
    Quote Originally Posted by MGrayson View Post
    Hey Matt,
    pretty flower nonetheless, but what's bothering you ?
    All the best.
    Bart ...
  20. #970
    jonoslack's Avatar
    11,728
    Hey Matt,
    All the best.
    I agree, nice flower, but obviously, just like I am, he's feeling a bit shredded!
    all the best
  21. #971
    jonoslack's Avatar
    11,728
    Hi there Jono,
    All the best.
    The R lenses might explain it . . . but there was lots of IBIS work going on, and at least half the shots were with the 12-50 (not one of the longer lenses).
    Right now time to go out and shoot 300 photos would be good!
    I'll be interested to see how Mike gets on with his generic charger as well (mine seems to work fine, and it was really cheap).
    all the best
    . . . and it's good to have you around as well - always a calm, unassuming, wry and intelligent asset to any photographic discussion (it's a kind of compliment you know - I hear they can be terribly effective )
  22. #972
    brian1208
    Playing with the EM5 + olympus 45mm at f2.8 to get a nice background blur. The dendrobrium orchid was in my conservatory and the background is the garden seen through the conservatory window. I really like using this combo for shallow DOF images
    [IMG][/IMG]
  23. #973
    140
    Two from Brittany/France. The light there and the colors are beautiful.
    P7150293cs von Karl-H.Friedrichs auf Flickr
    P7170087tw von Karl-H.Friedrichs auf Flickr
    Karl
  24. #974
    Oct 2008
    Seattle, WA
    5,672
    Downtown Seattle and Lake Union from Gasworks Park; and, some people enjoying the day, on and off the lake.
    E-M5; 75-300mm; 75mm; 4s @ f/10; -2/3 EV; ISO 200
    E-M5; 75-300mm; 117mm; 200s @ f/8; -1/3 EV; ISO 200
    E-M5; 75-300mm; 75mm; 1/320s @ f/8; -1/3 EV; ISO 200
    E-M5; 75-300mm; 75mm; 1/200s @ f/8; -2/3 EV; ISO 200
    Cheers, Matt
    Zenfolio | Matt Driscoll
  25. #975
    Nov 2010
    NYC
    1,475
    4
    Hey Matt,
    All the best.
    all the best
    Exactly. New equipment is always fun, but has the flip-side of feeling clumsy and inartistic (is that a word?) while it becomes familiar.
    Best,
    Matt
  26. #976
    1,860
    ffective )
    I'm using a generic charger and two batteries also and they are working just fine.
    Diane
  27. #977
    1,008
    Quote Originally Posted by Diane B View Post
    Diane
    Diane, I see the ads for the generic battery and charger specify that the generic batteries are not compatible with the OEM charger. Does the OEM battery charge in your generic charger? If so, can you show us which one you are using? I don't want to keep track of which battery goes with which charger. I'm ok with using the generic charger with all my batteries, especially if the charger has the fold-out prongs (I hope).
  28. #978
    Senior Member Ario Arioldi's Avatar
    Mar 2009
    Milano, Italy
    776
    Panaleica 45/2.8
    Ario
    www.arioarioldi.net
  29. #979
    1,860
    Tom. this is the link for the charger and 2 batteries I bought on ebay. It was recommended by someone who had done some testing and found it safe. What do I know about batteries (except for many years Ive used 3rd party plus OEM batteries in DSLRs and my m4/3s too)? LOL.
    The charger plugs right into wall so great for travel and it says specifically in the charger fits Oly BLN-1 and it does.
    Hope this helps.
    http://cgi.ebay.com/ws/eBayISAPI.dll...d=781533278005
    Diane
  30. #980
    Mar 2009
    Milano, Italy
    776
    Old "Tabią" decorated with flowers, Dolomiti, in the north east of Italy.
    Ario
    www.arioarioldi.net
    Likes 10 Member(s) liked this post
  31. #981
    Jun 2012
    36
    Decay by coloradophotog, on Flickr
    My VW by coloradophotog, on Flickr
  32. #982
    Bristol, UK
    1,473
    First is with the 45mm which I picked up today (they had the 75mm but I walked away ). Second is the kit lens which I'm really enjoying for its versatility:
    Mike
  33. #983
    122
    There seemed to have been a bit of theme in the past on the subject of local walks, usually when the cat refuses to co-operate anymore as a model.
    Accordingly here we have 'Big Creek', and I'll confess there's been a bit of HDR massage.
    Cheers
    OM-D + Oly 14.42
  34. #984
    Oct 2008
    Seattle, WA
    5,672
    Beautiful posts, everybody. Harbor Island and back at Lake Union and the Gasworks Park.
    E-M5; 12mm f/2; 1/640s @ f/8; -1/3 EV; ISO 200
    E-M5; 75-300mm; 200mm; 1/125s @ f/8; -1/3 EV; ISO 200
    E-M5; 75-300mm; 200mm; 1/160s @ f/8; -1/3 EV; ISO 200
    Cheers, Matt
  35. #985
    Member jnewell's Avatar
    Feb 2012
    Boston, MA USA
    92
    Quote Originally Posted by tom in mpls View Post
    I label my batteries so i can keep track of age and rotation anyway so keeping track of which goes in which charger is very easy. I am currently using one OEM and two aftermarket batteries (not by choice) but find that carrying a second charger is not an issue and provides the benefit of being able to charge two batteries at the same time. The connection issue with the OEM charger I solved with one of the little Apple folding prong/figure 8 charging block adapters, which is smaller than a battery...in storage, it nests neatly into the battery slot in the OEM charger!
  36. #986
    Senior Member f6cvalkyrie's Avatar
    Feb 2009
    Belgium
    1,608
    29
    Close-up fun with the E-M5 and Micro-Nikkor 200/4
    C U,
    Rafael
    E-M1/GH2/G1 Full Spectrum & lots of lenses
    http://www.flickr.com/photos/f6cvalk...th/9226689839/
  37. #987
    jonoslack's Avatar
    11,728
    Lots of lovely shots around
    time to shoot is sparse!
    Here are a couple from the last day or so:
    Saul Needs A Shave
    45mm f1.8 at 4000 ISO
    Hollyhock Heaven (from the loo window)
    Leica 75mm f2 summicron ASPH
    Kate sympathises with Silas (having trouble with Angry Birds again?)
    45mm f1.8 at 2000 ISO
  38. #988
    Knorp's Avatar
    3,529
    Saul Needs A Shave
    What a fantastic portrait, Jono. Reminds me of b/w films of old
    sometimes you worry me: why is time sparse ?
    All the best.
    Bart ...
  39. #989
    jonoslack's Avatar
    11,728
    All the best.
    Thank you Bart
    . . time is sparse because I have so many things to do . . . which is pretty lucky I guess
    Why does it worry you?
  40. #990
    Nov 2010
    NYC
    1,475
    4
    Probably just wants to see more photos, Jono.
    --Matt
  41. #991
    Pratamnak
    8,804
    2022
    +1
    What I just said on FB
    Things I sell: Stock photography by Jorgen Udvang at Alamy
  42. #992
    Apr 2012
    51
    OM-D with 45/1.8
    Blue by DarrellC, on Flickr
    OM-D with 45/1.8
    Grain Mono by DarrellC, on Flickr
  43. #993
    Knorp's Avatar
    3,529
    Well, for instance if my bank balance is healthy enough ...
    But no, I'd rather see you take care of yourself.
    You seem to be always busy of late.
    People start talking you know ...
    All the best
    Bart ...
  44. #994
    Sarasota
    942
    16
    Venice in the Evening - I will admit to more than a little work being done on the photo. However a testament to the stabilization in the camera. I am sure I leaned against something, but still...
    1.6 seconds at 2.8 with the 25 1.4
    20120709-P7090037_3tonemapped by jmmtampa, on Flickr
    Jim
    Likes 13 Member(s) liked this post
  45. #995
    Senior Member Tesselator's Avatar
    Aug 2010
    Japan
    695
    Lovely shots everyone.
    More later - in haste now. However, my OMD was put through it's paces over the weekend - a whole' day's rain and mud, with it and the P 12-35 slung over a wet shoulder - then nights in a steamy humid tent.
    All went well - more pictures later, but we did have fun!
    all the best
    Where is that? What event?
  46. #996
    Feb 2009
    Belgium
    1,608
    29
    Quote Originally Posted by Tesselator View Post
    WOODSTOCK
  47. #997
    Mar 2009
    Milano, Italy
    776
    A couple with 45/2.8
    Ario
    www.arioarioldi.net
  48. #998
    Jul 2012
    35
    Here's another couple I took in the garden today - still using the kit 12-50 while I wait for my mount adapters. I know these aren't anywhere near as good as most of the shots you guys are putting up but I'm enjoying taking them. Hope I'm not boring anyone...
  49. #999
    Bristol, UK
    1,473
    Quote Originally Posted by Jorgen Udvang View Post
    +1
    Jono, without question one of your best - great portrait!
    Mike
  50. #1000
    Bristol, UK
    1,473
    First proper day shooting with the 45mm:
    Mike
