Question re. Milich GM adapter
Martin S
Just received the adapter, and used it with LTM to M adapter ring on CV 15mm lens.
Works fine. But one problem, I can't remove LTM adapter from GM adapter. I can release the locking pin, and the ring rotates easily. However, the ring won't release from the GM.
Any ideas??? Anyone else had a similar problem???
I already emailed Mr. Milich, but I would like to remove the ring so that I can try some other lenses today.
Thanks.
Martin
scho
Thanks.
Martin
Martin, Did you try leaving the lens mounted when removing the LTM from the GM adapter? I was fooling around with mine earlier today and had no problem, but I did keep the lens attached to the LTM adapter when separating from the GM.
First time I tried close focusing with the little CV15 on the G1 and it does quite well (see below). I had been using the CV15 for a couple of years with the M8, but only for landscapes where I essentially used it as a fixed focus lens (no RF coupling).
Regards,
Carl
Martin S
Thanks Carl. I will try your idea.
BTW The CV 15 mm works very well, and I can really FOCUS this lens.
Thanks again.
Martin
JimBuchanan
Since we are on the subject of the G1 with 15mm Heliar, could I ask how it performs on the G1?
I have 28 and 50mm M lenses and feel I need a wider angle. I was thinking of a 21mm for a 42mm effective normal lens. Is the Heliar 15 slow f/4.5 speed an problem for the G1?
K
kiloran
I guess it depends on what you're shooting. If you're doing street stuff its probably ideal, as it will be for well-lit landscapes. Might be a challenge on a gloomy day - to my eyes the G1 is good up to ISO800 but you wouldn't want to use that for an expansive landscape shot.
