Cosina has just released a 20 mm f 3.5 pancake style lens in either a Nikon F mount, or Pentax K mount. With the delay in releasing the Panasonic 20 mm pancake , this could be a great walk around lens.
It sounds like a good lens for the G1 with stacked adapters (Pentax K to 4/3. 4/3 to m 4/3).
However, this brings up some questions
1) Is an SLR lens better to use on the G1 than a RF lens due to the edge smearing?? (Other 20 mm lenses do exist in RF format).
2) Does stacking adapters alter the flange to sensor distance, and so prevent accurate, and full range focussing??
3) I'v seen great results with using SLR lenses on the G1 on this site, and I was wondering if there are other problems caused by stacking adapters, and thus adding distance from the back of the lens to the sensor??
Thanks for your help.
Martin
Martin
