Results 1 to 3 of 3
Thread: Lens hoods for Voigtlander lenses
    I find the 15mm and 25mm CV lenses are very prone to flare on my G1 and the tiny lenshoods supplied don't help much.The lenses don't have a standard filter thread and the purpose made hoods for 35mm probably don't provide enough shielding on MFT
    Anyone come up a solution?
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    Re: Lens hoods for Voigtlander lenses
    You can might be able to make something using one of the Series filter adapters. Some of these have malleable flanges designed to allow them to slip over and grip the lens bezel.
    Member laptoprob's Avatar
    Apr 2009
    39mm filters kinda fit both of those lenses. Within the 15's tiny hood you can clamp a filter if you make it a little bigger with adhesive tape. Add an empty filter ring and you have a hood.
    The 25mm is threaded for 39mm filters. So if you add a size 39mm screw-in hood for a 50mm lens it should work out.
