http://cgi.ebay.com/Lens-Summicron-...|66:5|65:12|39:2|240:1318|301:0|293:1|294:200
Lens Summicron 2/35mm Tilt Shift f Panasonic G1![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I quite appreciate the creator dare to sacrifice a Leica Lens (you know, Leica is to keep well not to modify as usual). And the whole setting is inspiring.
I always wonder there should be a tilt shift adapter for G1 that almost all lens whatever for 35mm or APS-C can be used as the image circle is able to cover the sensor. Of course, problems are the limited working space since there is just 2cm space (the length of MA-1 4/3 to M4/3 ring) to make such a complex mechanism. May be just single function of tilt or shift is possible.
Although Lensbaby is already available for such kind of job but it is not as seriou as tilt shift system for architecture. If there is one, the contribution should be greater than a MA-1 subsidise.![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
