Results 1 to 3 of 3
Thread: Panasonic G1 Built in flash Problem
    Hi All
    I am having a problem with my G1's built in flash. Basically, it doesn't work regardless of which mode I put the camera in even if I set it to "Forced Flash". When I press the shutter, the flash icon would blink red and won't fire. I have tried recharging the battery to full cause the manual says a blinking red icon means the flash is still charging so I thought maybe the battery didn't have enough juice. But still the same after recharging the battery.
    Has anyone seen this before ? Any settings that I may have accidentally changed that caused this ? Any inputs would be appreciated. Thank you
    Re: Panasonic G1 Built in flash Problem
    I remember seeing just a few issues along these lines when the G1 first came out. As I recall, they had to send the camera in. I don't use the onboard flash so can't comment on that.
    I'm assuming that you have raised the flash though. That was a problem for several people--expecting the flash to raise and go off--but hadn't actually physically raised the flash. You must do this first.
    Yes I did raise the flash. It was working fine the other day and the problem just started last night.
