Pentax 67 120 soft focus
karlfoto
Hi Grp
I am interested in using the 120mm as a flat field lens for backpacking as it is a small package and relatively light and has a good reach for what I want to use it for.
My question was based on this note in the operating manual which says 'If the lens is closed down to more than f11, it will produce no soft-focus effect, and can be used as an ordinary lens'.
As I can't get a copy to check if this is true or not, if someone out there uses this lens could they post an image of it at f16 set to infinity so i can have a squiz to see if it will have everything in sharp focus.
Thanx
