5DMKII Dead?
scho
I took the camera out today, set up on tripod with my new 24 TS-E II, did prelim framing in viewfinder, clicked on live view and no image - just black screen. Tried taking images (with and w/o live view) and all appear black. Opened one in CS5/ACR and did auto levels and result is below. We have had extremely humid weather for the past few days but the camera worked perfectly until today. Still under warranty and I've reported problem to Canon, but has anyone else run into a similar problem with the 5DII?
Bob
Administrator
Staff member
Nope, I have not seen that with the 5DII,
Although I am pretty sure that there won't be any difference, have you tried with another card?
If that is the same, as I think it will be, it is time for emergency treatment for the poor thing.
-bob
scho
-bob
Thanks Bob. Yes, I tried a different card with same results. Afraid you are right and will need to send the camera to Canon service.
scho
Jack and TokenGirl,
Thanks for your sympathy - bummer is right. First email response just now from Canon tech support was to see if mirror and shutter are working properly - they are working fine. Next step will be a call Monday AM to the service center and shipping it off for repair. Strange, because although the humidity was up, it was not extreme and the camera wasn't exposed to any abrupt changes in either temperature or humidity. I've been using my little G1-IR camera along with the 5DII and the G1 is doing just fine (also works well with the 24 TS-E II).
scho
I confirmed with Canon support that the mirror and shutter were fine and they think (as I do) that the sensor is at fault and suggested sending it in for repair. I'm bummed about the camera failure but impressed with the fast response of Canon support (all on a Sunday afternoon in a matter of a few hours). Hopefully repair will also be quick and painless (warranty covered).
Last support response:
"Thank you for your inquiry. We value you as a Canon customer and
appreciate the opportunity to assist you.
That unfortunately sounds like an issue that would need to be looked at
by our factory service center. It sounds like their is a problem with
the image sensor. You may want to try resetting the camera settings and
custom function in the menu to see is there is a setting causing
problems but service is likely needed from the description of what is
happening."
scho
Just a follow-up on my 5DII failure. Camera came back today from Canon Repair Center in NJ (Quick service turn around). No prior notification or tracking info. Fedex tried to deliver this AM when I was out so I had to go pick up the camera at the Fedex center this evening. Came with simple brown paper wrapping with camera in a ziplock bag all in a brown box. Some quick test shots indicate that camera is OK again. Note said "...it was found that the part was broken so that the power supply did not operate properly. The cmos sensor assembly w/o FB data was replaced and product functions were confirmed. Adjusted exposure & focus, cleaned cmos and checked all to factory specs." I'm not exactly sure what all of that means, but at least I'm back in business again with the 5DII. No charges - all under warranty which expires next month. Whew!!
David Schneider
Carl,
When your warranty runs out, consider Toshio at T.F. Camera Repair, 27 Brunswick Woods Drive, East Brunswick, NJ 08816 tel: 732-238-8806. He's in my town and we are just 10 mins from Canon in Jamesburg, NJ. Canon has outsource tens of thousands of repairs to him over the years and he's recognized as one of the leading Canon camera repair techs in the country. He's generally faster, less expensive than Canon, plus you can talk to him. He's very old school and has been doing Canon repairs for 30 years. He's also a friend of mine.
spotmeter
Glad to hear your 5D2 is working again. I wouldn't want to go through the same thing with mine.
But I wouldn't toss out that tartan pattern from the faulty sensor. The more I look at it, the better it looks. You might be able to sell it to a fabric designer.
