Results 1 to 4 of 4
Thread: SOLD: SCHNEIDER 100mm F2.8 C-mount $375
    Yoji San
    C-mount lens
    Smooth aperture and focus
    Glass has no scratch, mark or fungus
    The body has no mark or scratch
    Comes with original front cap (Schneider) and original box
    Serial # 13 865 185
    More pictures can be seen here (or upon request):
    I often receive question about this beauty, even though it’s a Schneider lens people are worried concerning its performance compare to the Kern Yvar 100mm… First of all people don’t know that there is quite a big difference between Kern Yvar and Kern Switar. Switar is Zeiss quality, fast, heavy and great lens. Yvar is not, it’s cheaply made, light and slower by one to two stops compare to the Switar. Now back to the Schneider, here is a comparing “chart” so that you can see for yourself that the Schneider is definitely a notch higher then the beloved Kern Yvar 100mm
    As you can see the Schneider has a much larger range and let’s talk about how smooth the rings are on the Schneider… You can just change the aperture and m with the tip of your finger when the Kern requires you to grab it
    Kern Yvar 100mm
    F-stop Range: F3.3 – F22
    Focus Range: 8’ – ∞ (2.4m – ∞)
    Front Diameter: 31mm
    Weight: 180g (6.4oz)
    Schneider Xenar 100mm
    F-stop Range: F2.8 – F32
    Focus Range: 1.6m – ∞ (5.2’ – ∞)
    Front Diameter: 42mm
    Weight: 500g (17.6oz)
    Comparing pictures:
    Yoji San
    Re: FS: SCHNEIDER 100mm F2.8 C-mount $375
    Yoji San
    Yoji San
