Carl Zeiss Triotar T* - Lupe 5X
The Triotar T* Lupe 5X has a viewing field to cover the entire 35mm film format (24 x 36mm). The loupe is not only designed to provide a very bright and clear image but to do so with superb color reproduction and almost no distortion. The long eye-point (approx. 20mm) gives a comfortable view without tiring the eye during viewing sessions.
The bottom section of the Triotar T* Lupe 5X is interchangeable allowing the user to select a transparent base for reflection print viewing or a solid base for transparency viewing.
• Lens configuration: 3 elements in 2 groups • Focal length: 50mm. • Eye point: 20mm from the ocular. • Magnification: 5X • Effective viewing field: 45mm • Lens coating: Carl Zeiss T* Coating. • Diopter range: + 0.5 D to - 4 D • Dimensions (at 0 D): 52mm (diameter) x 62mm (length) (2-1/16" x 2-7/16") • Weight: 95 grams (3.4 oz)
This items is in MINT condition, and it comes with both opaque and transparent bases. $135 or best offer
