Likely found - Leica 75 lux
Steve Fines
I'd like a latest version, 6 bit, 75 Summilux. Not really interested in others.
Have one laying around?
I'll have a beautiful 75 'cron to sell as soon as I find one in case anyone is interested in a trade.
Rafael
Re: WTB Leica 75 lux asph
Just an FYI, the 75mm Summilux is a fantastic lens. But it is not actually an ASPH. Good luck with your search. You will be well rewarded when you find one of these.
D&A
Hi Steve,
As far as I know, none of these lenses came natively from Leica with 6-bit...so those were coded by Leica later on when owners sent them in. In regards to Canadian versions vs. German versions (I'm refering to the later Canadian ones that look identical to the German ones...not the very early Canadian ones whose designed looked different)...I've yet to see even a smidge of optical differences by examining the crops at 100% at all f-stops and also each version was just as likely to need or not need focus adjustment. In fact a few years ago a group of us got togther and both tested and relayed our experiences when we purchased our lenses new and in use. It turned out the Canadian versions by chance were better adjusted out of the box than the German versions..but it just as easily could have gone the other way if we continued to test other samples. I've heard from others that found their German versions just fine. These were tested on M8's & M9's. We all came to the conclusion that nothing really distingushed one version from the other except the price.
As Rafael and others here have said and showed in their posted images...this lens is truly a very special lens when a good sample in terms of focusing is found (or properly adjusted).
Dave (D&A)
Steve Fines
Thanks for all the offers.
I've found one that is within driving distance that I am going to check out next weekend.
LV1962
Same glass but later made in Germany ones (11810, serial numbers 38xxxxx+) are a little lighter than earlier canadian made versions (560 grams vs 600 grams).
