Don't use these anymore so they have to go. Very nice sturdy small tripod that's perfect for travel. Has the Rapid Center Column. I think it's also called the G1026. Discontinued but here are the specs
Finish: Gray & Black Enamel
Material: Anodised Aluminium
Maximum Height With Center Column: 48.8 in/124 cm
Maximum Height Without Center Column: 38.2 in/97 cm
Minimum Height: 14.8 in/37.5 cm
Closed Length: 16.1 in/41 cm
Leg Sections: 4
Foot Type: Rubber
Maximum Load Capacity: 5.5 lb/2.5 kg
Weight: 2.2 lb/1.0 kg
It can hold a DSLR with a medium lens no problem. Just get a good head.
Price is $150 Net to me. Everything else is extra. Local deal would be great but I can ship if needed.
