Results 1 to 1 of 1
Thread: FS: Gary Fong Lightsphere II model P2
    Senior Member bradhusick's Avatar
    Seattle, WA USA
    Original owner selling excellent condition Gary Fong Lightsphere II model P2.
    The P2 model is compatible with:
    Canon 299, 540EZ, 550EX & 580EX II
    Minolta 5600
    Pentax AF500FTZ
    Quantaray QTB-7500A, QDC-900/900WA, QTB-9500A
    It is not a universal fit - it is designed for these flashes only. The fit is loose so you can use some masking tape to hold it securely to flashes (I have used black masking tape on many occasions).
    Includes the P2 Lightsphere II with the standard inverted dome.
    The Lightsphere is a large, round, soft and flexible diffuser that slips over the front of compatible flash units. The inside of the Lightsphere is completely textured to make the light dispersion even more "soft" than it would be otherwise. And because of this design, it is possible to make the material more translucent, keeping the unit from losing a lot of light while actually increasing the diffusion and softness of light.
    An opaque color has been added to the inside of the Cloud version, and this "frosted" version creates an even softer effect, which makes it ideal for close-ups, portraits, and event photography.
    Especially ideal for vertical flash shots where the flash coverage is still similar to horizontal shots, due to the large rounded shape of the diffuser. Minimizes the need for a flash-flip bracket.
    $32 includes free ground shipping in CONUS.
    Brad Husick
