Results 1 to 2 of 2
Thread: FS: Gitzo G1228 MK2
    Senior Member markwon's Avatar
    Jan 2009
    FS: Gitzo G1228 MK2
    This is one of the most robust and compact carbon fiber tripods available. Gitzo quality is unrivaled. My wife paid $500 for it. It was gift but I never used it since I shoot smaller rangefinders and never needed a heavy duty tripod. Comes with original box and packaging.
    $390 shipped.
    Description from B and H
    The 1228 is a remarkably rigid tripod capable of holding most 35mm & medium format gear and even some lighter field 4x5 cameras. The abundant advantages of carbon fiber make this tripod remarkable in many respects. Vibration reduction is wonderful, it is light enough to take everywhere and goes up and down very quickly. The build quality, ergonomics and non-rotating center column with positive locking action are the best in the industry. If you use 35mm and medium format gear and are looking for the ultimate in an ultra-light tripod of backpacking size, look no further than the 1228.
    Stainless steel weight hook at the base of the center column
    Fits comfortably on most camera backpacks
    Model Number
    B&H # GIG1228
    Manufacturer # G1228
    Maximum Height 60.6" (153.9 cm)
    Maximum Height w/o Column Extended 52.0" (132.1 cm)
    Minimum Height 12.6" (32.0 cm)
    Folded Length 21.3" (54.1 cm)
    Load Capacity 17.60 lb (7.98 kg)
    Leg Sections 4
    Leg Lock Type Twist
    Independent Leg Spread Yes
    Center Column Sections 1
    Center Column Type Rapid
    Center Brace No
    Spiked Feet No
    Head Mount Thread Size 1/4"-20 & 3/8"-16 (reversible stud)
    Weight 3.40 lb (1.54 kg)
    Not manfrotto arca Swiss Kirk markins giotto
    Jan 2009
    Re: FS: Gitzo G1228 MK2
    SOLD, locally.
