WRS 5000 Wide Camera System
jnseibert
Decided to not do this type of photography so basically brand new. Took out of box and tried it once. Asking $3,600.
Cambo WRS 5000 camera-8.jpgCambo WRS 5000 camera-7.jpgCambo WRS 5000 camera-6.jpgCambo WRS 5000 camera-5.jpgCambo WRS 5000 camera-4.jpgCambo WRS 5000 camera-3.jpg[/ATTACH]Cambo WRS 5000 camera-2.jpgCambo WRS 5000 camera-8.jpgCambo WRS 5000 camera-7.jpgCambo WRS 5000 camera-6.jpgCambo WRS 5000 camera-5.jpgCambo WRS 5000 camera-4.jpgCambo WRS 5000 camera-3.jpg
The Cambo WRS-5000 series is the top model of the Wide RS Family, made from high grade aluminium as used in aerospace technology.
The movements are driven by accellerated spindle gears, operated by XL size stainless steel driveknobs with excellent grip. These precision-geared controls provide architectural photographers with many of the image-placement movements they require, while giving digital photographers the ability to create amazing vertical and horizontal panoramic images through stitching several exposures together.
An integrated weight compensation for the digital back equalises the movements for rise and fall to the same effortless feeling.
Additionally many of the Lenspanels can optionally be acquired with a Tilt-Swing possibility, to add Scheimpflug settings for increased depth of field, in both horizontal as vertical plane or intentionally selective sharpness where needed.
Like the other Cambo Wide models, the WRS-5000 features interchangeable interfaces for Hasselblad, Leaf, Phase One and Sinar digital backs. Mounts are available for Hasselblad V, Hasselblad-H, PhaseOne/Mamiya 645DF and Contax 645AF compatible camerabacks. A dedicated interface plate hosting both Leaf AFi and Sinar HY6 backs is also available.
In order to accomplish nearly any architectural or landscape assignment, the Wide RS accepts the full range of WDS lens panels that incorporate the Schneider Digitar and Rodenstock Digital lenses. Choose from focal lengths ranging from 23mm up to 150mm and more.
Size 190 x 175mm (W x H) incl. handgrips and tripod mount
Lightweight only 1.2 kgs (excl. lens)
Horizontal shift 45 mm (22.5 mm left/22.5 mm right)
Vertical shift 40 mm (25mm / 15mm)
