Gitzo G-1228 Mountaineer Reporter Carbon Fiber Tripod
The 1228 is a remarkably rigid tripod capable of holding most 35mm & medium format gear and even some lighter field 4x5 cameras. The abundant advantages of carbon fiber make this tripod remarkable in many respects. Vibration reduction is wonderful, it is light enough to take everywhere and goes up and down very quickly. The build quality, ergonomics and non-rotating center column with positive locking action are the best in the industry. If you use 35mm and medium format gear and are looking for the ultimate in an ultra-light tripod of travel & backpacking size, look no further than the 1228. Closed cell foam/Cordura leg protectors installed since day one; included at no extra cost.
Price: $285 includes free ground shipping to Continental USA.
See more tripod photos at: Gitzo 1228 Carbon Fiber Traveler Tripod
Maximum Height 60.6" (153.9 cm)
Maximum Height w/o Column Extended 52.0" (132.1 cm)
Minimum Height 12.6" (32.0 cm)
Folded Length 21.3" (54.1 cm)
Load Capacity 17.60 lb (7.98 kg)
Leg Sections 4
Leg Lock TypeTwist
Independent Leg Spread
Center Column Type - Rapid
Head Mount Thread Size 1/4"-20 & 3/8"-16 (reversible stud)
Weight 3.40 lb (1.54 kg)
