The GetDPI Photography Forums
Go Back   The GetDPI Photography Forums > Other Discussions > Gear Garage
Gear Garage Includes Computers, Scanners and any other photography related equipment not listed elsewhere.
Like Tree1Likes
  • 1 Post By tsjanik
Reply
Old 6th March 2013   #1
Sunwayfoto Long Lens Support
I recently acquired a Pentax 600mm lens for my 645D. It quickly became apparent that more stabilization than the Acra-Swiss Z1 could supply was needed. I found a long lens support on Amazon made by Sunwayfoto. I took a chance and ordered that along with a rail and two clamps, allowing me to quickly adjust for other lenses. The items are extremely well made and appear to do a great job of stabilization. Note solid attachment at the lens foot and body along with support of the lens. Highly recommended.
_IGP1179 by tsjanik47, on Flickr
bensonga likes this.
tsjanik is offline   Reply With Quote
Old 6th March 2013   #2
D&A
Re: Sunwayfoto Long Lens Support
Tom, great shot of the set-up! As you know I'm in the same boat with regards to having the same lens and body and have found loss of sharpness with the slightest bit of movement or vibration. Surprisingly, mirror slap actually hasn't really contribute to much deterioration of apparent image sharpness when bottom of body is well supported as well as lens...simultaneously. I think your set-up is more stable and vibration free than mine, but I'm able to track moving subjects quite easily. It's a tradeoff and of course dependent on what one is shooting.
Two questions. The support on the front of your lens as shown..is the barrel nestled between two pieces of rubber while resetting on some surface? Hard to tell from the pic.
Lastly may I ask how much the set-up was minus the ball head? Thanks!
Dave (D&A)
D&A is offline   Reply With Quote
Old 6th March 2013   #3
I can track perfectly with this since the only attachment is the ball head. I just tried adding a Manfrotto long lens support which attaches to the tripod leg and the side of the 645D - absolutely rigid. Cost of what you see about $270. The support in front is likely unnecessary; it is two pieces of rubber similar to the RRS. I'll do some tests later, but this seems to be a great system. The Manfrotto adds about another $75 and still allows limited adjustment, but with three more knobs to tighten. Pricey, but what's the point of using this lens if the shots aren't sharp? The lens itself is very sharp - if it doesn't move
Old 7th March 2013   #4
D&A
Tom, thanks for all the great info. I only have intermittent power and no Internet service due to heavy wet snowstorm we've had here. Only my cell phone and what limited charge I have with it. I've used the Manfrotto long lens support for many years but found for tracking and swiveling, it was a hindrance but for stationary subjects, provided rigid support as you pointed out.
I just sent you a PM here with some questions and a request for info. Thanks!
Dave (D&A)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Search Engine Optimization by vBSEO 3.6.0
