rayyan
I am stuck! Need help in 101 form please.
Set-up
I have my latest iMac set-up running OSX 10.8.4
I am running CS6/ACR Bridge on it.
I bought an external WD 3T hard-disk for general b/u purposes. Copying image folders ( and their sub-folders ) from the machine HD and additional external ones.
I have formatted it for Mac OSX file system. But not using it with Time Machine or for routine auto b/u.
Problem:
Whenever I try to drag and drop a folder from one external hd to the new 3T HD I get the following error:
" You can’t copy “.BridgeCachet” because it has the same name as another item on the destination volume, and that volume doesn’t distinguish between upper- and lowercase letters in filenames. ".
Obviously I cannot go to each folder and erase the hidden .file
Guess it is created by Bridge when I use it to process images in a folder.
Every folder I try to copy comes up with the same error message.
Request:
Any suggestions as to how I might resolve this issue.
Thank you all in anticipation.
p.s I have tried to purge all cache thumbnails and previews stored from the Bridge preferences. But zippo!
I am stuck!!:banghead:
__________________
Set-up
Problem:
Request:
__________________
