Direct Raw converted?
Rawfa
I just came back from 4 days in Budapest with almost 9gig of photos in RAW format. My wife wants a copy but she wants the photos in JPEG so that she can view them with the ms windows browser. Is there a direct drag and drop raw converter that can do this?
D
ddk
LR, PS, C1, SP or almost any other raw converter that I've tried will batch convert your files.
R
Ranger 9
How do you normally convert your raw files? If there's a way to run your preferred converter in batch mode, that probably will be the easiest way to do it.
For example, if you usually use Photoshop, you could convert one file the way you like it while recording an action, then use File>Automate>Create Droplet to change that action into a drag-and-drop thingie.
Rawfa
Hi guys. I usually only convert from RAW the files I work on to post on my blog or print. Say I consider only 1gb from these 9gb interesting enough to print or publish, I'll take these files to PS, work on them and then save the jpegs for the web on a lower resolution and size. Can I do something like "select all" and then select the resolution and size and just leave it converting over night?
