Higher ISO noise control
ReeRay
I'm hoping someone can help me here with my processing routine and particularly a problem I am having controlling noise at higher ISO viz 3200.
I shoot (RAW only) a lot of dimly lit and varying light theatre productions using a Canon 5D MKII.
I zero the camera noise and sharpening. I zero Capture One also. I apply NR as a first action IN CS3 and use the pre-set recommended Canon filtration which I also reduce by 50%.
Here's the result of an image at 3200 ISO which at 100% is pretty grim.
Can you suggest parameters to improve my PP?
I'd be most obliged for your input
Thank You
Sr. Administrator
Staff member
Seriously, try C1 with NR set to around 25/40 for the 5D2 at 3200... If you don't like that, I really do like DFine and you can download a free demo...
Here is DFine run on your crop in AUTO mode. You can set it up to run as a layer then adjust opacity to taste. You can also dial back the measured settings to taste befor applying it. Best of all, since it loads as a layer, you can run multiple iterations, then mask to taste.
ReeRay
What a great tip from Jack.
I've downloaded the software and what a revelation.
Thumbs up for that one Jack
