Results 1 to 2 of 2
Thread: Spyder 3 Pro monitor calibration?
    Mar 2011
    Beach Haven, NJ
    Not sure where to post this, but here goes:
    I have a new PC. I run two monitors. Monitor 1 is a Samsung SyncMaster 931B. Monitor 2 is a cheap used uncalibrated monitor, a Philips Btilliance 150P3. Control Panel correctly identifies monitor 1 as a Syncmaster 931B, and number 2 as a Philips. When I try to calibrate #1, Spyder gives me a choice of "Generic PnP 1", or Syncmaster. I have to choose Generic PnP, to calibrtate it. If I select Syncmaster, spyder thinks that is the cheap Philips, and jumps to that screen. I have calibrated monitor 1 using "Generic PnP-1", but feel I may be losing some performance not using the mfg's driver. Can anyone help? I did download the latest digital Syncmaster driver and installed it. Spyder tech people said swap plugs on back of PC. No help.
    Beach Haven, NJ USA
    Subscriber Member weinschela's Avatar
    New York suburb
    Re: Spyder 3 Pro monitor calibration?
    How about calibrating one without the other connected?
    Selection of work:
