Help needed
M
Manatee
I want the M8.
Before taking the plunge I borrowed a M6 to get the RF feeling.
I'm afraid I like RF!
I shot some tests with a 35 cron (old) on Tri X the other day and had the film developed and scanned. I got a disk with 72dpi scans. I appeared to me that the unprocessed are very 'grey' without contrast etc. Since this is the first time I used film and transferred into bits and bytes I was wondering if this is normal.
Did my dealer did a bad job?
The first picture is the unprocessed JPEG on the second one I only used 'curves'.
I use CS2.
Please help.
Thanks,
Rob
jaapv
I'm not surprised - scanning is usually either a DIY job using a decent scanner like the Minolta or Nikon offerings, or a highly specialized professional task to get real high-quality stuff. The run-of-the-mill around the corner scan is always fit only for the dustbin.... I fear, if you like rangefinders and want to go digital, it will cost you real money -something like M8 money :rolleyes:;)
Chemical photography, imo, should stick with chemical and and digital with computers, and never the twain should meet....
Daniel
I use CS2.
no this should not be normal. can you find out what sort of scanner you dealer used? can you give a bit more details regarding the service provided by your dealer? you may have needed to clarify what you needed. perhaps you ended with a jpg file from your dealer because your dealer assumed you only wanted a simple scan. sort of like a proof before you decide if this image is worth scanning in higher resolution.
i recently had a few slides scanned by a lab. the slides were done on a drum scanner. the scanned files were between 90 and 100 mb. they were relatively large because i wanted to print up to 16 x 20. the files were 16-bit TIFF and not JPG.
if jpg file is the best your dealer can do, then perhaps this dealer is not equip to handle your needs. i suggest looking around for professional labs that can do quality scans for you. my lab charged me between 1 and 2$ per mb, and burning to CD is extra.
i hope this was helpful.
—dan
edit -you're in the netherlands? here's what i found by chance. http://www.acecam.com/holland.html.
M
Manatee
Thanks Jaap and Dan.
I asked around and I will use another lab. (Jaap; Kleurgamma in Amsterdam)
It appears that I only got low res. scans from my dealer.
Rob
