Results 1 to 3 of 3
Thread: Attaching a Nikon DSLR to an old Kodak view camera
    Jun 2012
    I did some google searches and found it has been done with a Nikon D800 and a single rail 4x5 view camera. I'd like to know if anyone has bought or built a pack for a view camera. My questions:
    What back did you use and what extention tube did you use?
    What lens did you use on view camera?
    Would a 65mm lens or a 180mm lens work?
    Does AF work on the digital camera work?
    Senior Member Lars's Avatar
    Sunnyvale, California
    Re: Attaching a Nikon DSLR to an old Kodak view camera
    65 sounds tight - flange focal distance might be a problem.
    This chart shows the flange surface to rear of lens distance for Schneider lenses - the 58 XL has 31 mm, and a flange focal distance of 70 mm, which leaves 39 mm distance from lens to film plane.
    Wikipedia states that Nikon F mount has 46.5 mm flange distance, so you cannot focus a 58XL at infinity.
    Jul 2010
    Sacramento, CA
    I use my d800e on my Cambo 4x5 quite a lot. Lars is absolutely correct even a 150 will not focus at infinity. I use a 210 or longer lens and it works just fine. What you gain is swings and tilts, I stitch and get really a big file, but I can stop down to f/32 or f/45 and it doesn't matter a whole lot since I am making the equivalent of a 4x5 negative. Not a lot of magnification.
    Mostly I use this with a 13" Cooke, no swings and tilts, but a big file and at f/6.3 bokeh to die for. It is big and bulky and ever so slow.
    I am not certain if you meant auto focus, but I would think that, that would be one heck of a trick.
    Oddly focusing is not that difficult, and on the 210 since it is a f/5.6 lens the focus check thingy works just fine.
    I use manual exposure however, otherwise the camera makes some really odd decisions.
    The adapter is made by Fotodiox and works just fine
