7 inch reflector for elinchrom
Sr. Administrator
Staff member
No. You'll need the Quadra to Standard reflector adapter, then the 7" grid reflector OR use the 7" grid reflector for the Quadras.
Dustbak
No, that is not true. There is a 7" (18cm) reflector for the Quadra system. This will also take ordinary Elinchrom grids. No need to convert to the regular Elinchrom system before (you do need to get the 18cm reflectors though).
If the Balcar grids are similar to the Elinchroms they will fit in this one.
