O
Omnicow
Hello! I recently came into possession of an assortment of Broncolor lighting equipment with which I plan to shoot product photography. Amongst the equipment is a trio of Hazylights, the fiberglass kind, which seem to have varying model numbers but almost identical design. The issue is that the diffusers in the front are either missing, in one instance, are quite aged and yellow. I'd like to replace the diffusers on all of them if this can be done affordably. It seems that they are some sort of film held onto an aluminum frame by an adhesive tape. I should just be able to replace the film. Does anyone know where I can find a material matching manufacturer's specifications?
Thank you very much!
-Ryan
-Ryan
