Results 1 to 2 of 2
Thread: Elinchrom Quadra adapter
    Mar 2008
    the Elinchrom Ranger Quadra Reflector Adaptor for EL Reflectors is expensive and its plastic parts can easily broke.
    Elinchrom Ranger Quadra Reflector Adaptor for EL EL 26339 B&H
    1. Is there a better made and less expensive adapter to attach Elinchrom light modifiers to Quadra heads ?
    2. I'm also very interested in an adapter to attach Hensel light modifiers to Quadra heads. Cannot find Hensel to Quadra adapter for many years.
    Re: Elinchrom Quadra adapter
    Well I've never had an issue with the plastic breaking, I have had problems with the metal bending. Meanwhile Elinchrom finally recognized the issue and came up with the Quadra Adapter Mark II.
    FotoFlits - Ranger Quadra Reflector Adapter MK-II
    Not yet available in the U.S. it is available from an eBay seller based in Israel (I bought two and love them). They're more expensive than the original by the way.
    When push comes to shove, the market for Quadra to large modifier adapters is so small that there hasn't been much of a call for third-party solutions. Lastolite had its adapter and Mola had its adapter -- not that I'd mount a heavy adapter directly to the Quadra head. I do have a Mola Demi and have it mounted to the Quadra with one of these
    Mola Lumi Three Tilt Bracket for Elinchrom Ranger Quadra s or A Flash Heads | eBay
    Good luck with your search.
