Results 1 to 1 of 1
Thread: Bracket for Metz 70/76 Series
    Nov 2010
    Ottawa, Canada
    48
    I like the way this bracket is designed:
Size:  40.6 KBName:  s-l1600-1.jpg
Size:  34.0 KBName:  s-l1600-1-1.jpg
    Rather than clamp to the flash handle or with a shoe attachment, it holds only the head in an adjustable clamp; the head also rests on a rubber, no-slip platform.
    But it's too small for the Metz 70/76.
    Is there another kind of flash bracket that does work with larger units like the Metz 70 or 76 series?
    They're about 100mm wide (at the widest point) and 55mm high.
    Alternatively, if there's no such solution for the Metz, can anyone recommend some kind of set-up?
    I'm trying to put together a battery-powered portable flash head of about 200 w/s that can accommodate a small soft box (20"-24") and mount easily to a standard light stand.
    Thank you in advance.
