Who ever shoots wide open?
gogopix
Subscriber
There;s been a lot of discussion over the years about 'fast' lenses. We hear
" really need a fast lens for this situation where I don't have flash option... etc etc etc.
Think-why are lenses made at the f number selected?
Well it is a trade-off; size, weight, speed, resolution (line per) , method of focus (yes) etc.
Why would anyone ever take a shot wide open except for maybe catching a theif on a dark night? :D
If you make a 2.0 lens it SHOULD be better at 2.8 than a 2.8 is at 2.8 UNLESS you design it for more resolution.
Yes, Leica tends to have workable lenses at 2.8 to 5.6 whereas I don't think I would use an MF lens less than 5.6 most times. Just no DOF (Just so many "I got the nose hairs in focus, and all else is just bokeh" shots I can stand ):ROTFL:
For one thing, the faster lens is easier to focus since you do that at full aperture, the AE stops down. And yes there are the emergencies. I always want 2 stops head room in a lens-if I buy a 1.4 over a 2.8 its because I want to shoot f4 instead of f5.6 or f8.
Some viewfinders just don't work over 5.6 (Brightened screens will go dark on one side on a prism at 5.6 and over)
So again, when judging lenses maybe it is best to compare 'real world" f stop- where we are likely to shoot. The comparison's of lenses at wide open is technically interesting , but that is not to say another lens doesn't 'overtake' in some quality stopped down.
I can't think of a wide open shot that I EVER used; but then again, I am not a pro. Maybe a pro knows how to usre it. Maybe the 'mood' shot at a wedding, etc. I can go for that.
Wre mere mortals can barely keep the focus NEAR the subject, much less deal with 2-3" DOF.
Any comments?
Victor
Dale Allyn
Some do not consider absolute sharpness to be the only goal, or even primary goal, in the making of many images. Some images excel because of how shallow depth of field is used in the composition. Some lenses draw in a certain way when wide open, eg. the Canon 85mm f/1.2 has a "look" wide open that is not quite the same at say f/1.8.
And if one wants to adhere to the "stop down a bit" idea, then starting with an f/1.4 allows one to still shoot at f/1.8 or f/2.0, get a shallow DoF and potentially very sharp images.
As I've mentioned in other posts, IMHO much too much emphasis is placed on pure resolution and "sharpness" at the expense of content, composition and "mood". I know this is almost heresy in some forums, especially gear oriented forums. Ideally, one seeks to have both, "sharpness" when needed, and the other elements of a successful image. Given a choice, I prefer content.
But in response to your main point, Victor, I like the shallow DoF for some images, or low-light usage because I do not like flash. :)
gogopix
Subscriber
Excellent point about sharpness- although IN GENERAL I like a sharp image, there are times when that is certainly not the main consideration. Content in my mind ALWAYS dominates.
That said, part of my point was the difficulty in GETTING the focus with shallow DOF. I think pros have the skill, even with sloppy viewfinders-I have seen some amazing shots.
For the rest of us, focus bracketing is a life saver. I can't tell you how often I click off three shots 'around' what I think is the focus.
But my point wasn't to shoot down full open-it was a genuine curiosity about where the image benefits from narrow DOF; gets the mood. I think your 'compromise' of going up a half or one stop for narrow DOF PLUS a little better clarity is a good one. Sometimes I think I do that just instinctively.
regards
Victor
Graham Mitchell
I originally chose the Rollei 6000 system partly because it had the fastest lenses overall. So it was a high priority for me, and I actually wish the lenses were even faster. I would easily use f1.4 at times if I had the option. I think Leica has missed an opportunity with the S2 by bringing out glass which is not the fastest in class.
"Who ever shoots wide open?
" really need a fast lens for this situation where I don't have flash option... etc etc etc.""
With all due respect, Victor... you're sounding more than a bit like a troll here. How long have you been shooting?
For one: wedding photographers and event (i.e. ballet) photographers can't shoot indoors with flash. Fast lenses are the only option if you want to succeed at your goal.
Second: fast lenses allow for better separation of subject and background. For street photography, anything BUT f16 and be there works! For portrait photography fast glass provides that dreamy effect that adds that element of romanticism to a shot. Just look at some of Marc William's shots.
Third: fast glass allows for shooting closer to optimum asa instead of having to shoot at 1600 + and deal with all the detail robbing noise.
Fourth: faster glass allows for faster shutter speeds (sacrificing depth of field) and can make the difference between sharp and mushy.
The list goes on...
"Think-why are lenses made at the f number selected?
"Why would anyone ever take a shot wide open except for maybe catching a theif on a dark night?"
See points 1-4 above
"If you make a 2.0 lens it SHOULD be better at 2.8 than a 2.8 is at 2.8 UNLESS you design it for more resolution."
Drink some more coffee, dude. That makes no sense at all. That comment contradicts itself.
"Yes, Leica tends to have workable lenses at 2.8 to 5.6 whereas I don't think I would use an MF lens less than 5.6 most times. Just no DOF (Just so many "I got the nose hairs in focus, and all else is just bokeh" shots I can stand )"
Once again: faster shutter speeds allow for sharper images. Not as big a deal with 35mm cameras that have IS in lenses or SSS in-camera... but MF has neither. Larger mirrors and larger shutters create more vibration w/MF cameras. If your goal is being able to print larger (and why else spend all the money on MF digital?), being able to get sharp results while hand holding is critical. Faster lenses allow for that as MF digital does not have acceptable IQ at 800+ asa.
"For one thing, the faster lens is easier to focus since you do that at full aperture, the AE stops down. And yes there are the emergencies. I always want 2 stops head room in a lens-if I buy a 1.4 over a 2.8 its because I want to shoot f4 instead of f5.6 or f8."
Yup.
"Some viewfinders just don't work over 5.6 (Brightened screens will go dark on one side on a prism at 5.6 and over)
Any comments?
Victor"
Paratom
I am going back and forth regarding the question shooting wide open or not.
However I have tried several times to take 2 images of same subject, one wide open and one stepped down a bit and in the end, if one nails focus and if the subject is placed in the right angle etc. shallow DOF does look very interesting to me. Specially interesting I find non-tele-shallow DOF shots.
Personally I have decided to shoot more often wide open.
Regards, Tom
D
ddk
I think that they might add faster glass at a later date, looking at the pricing of their faster m lenses they probably wanted people to buy into the S system first before scaring everyone away with ultra expensive fast S lenses.
gogopix
Subscriber
Does a shot like this (test shot with 110mm f2) explain it? 2-3" DOF is not a problem at all and is far too much DOF sometimes.
Dear Graham
YES. Thanks for answering my question :thumbs:- however provocative, it was a REAL question. (sometimes one needs to be 'creative' in the title to elicit creative answers :angel:)
Maybe its just fear of old eyes (67 miles on them) poor prisms, or back/front focusing (ALL cameras have to a certain extent)
Do you find you sometimes need to bracket focus? maybe its just sports and outdoor cityscpae/people. they tend to move (how annoying :D ) .
I think the speed comment touches on an important aspect of fast lenses - although I don't necessarily want WO of a 2.0 :)salute: graham on the cig man shot) a 3.5 or 5.6 lens is manageable.
Thanks for the responses (even you," troll caller" :ROTFL: )
Victor
Sr. Administrator
Staff member
My .02...
I personally find shallow DoF shots interesting, though it is not a high priority for my MF shooting.
The other side of the question is equipment capability. To be able to nail focus at the precise point you want reliably and repeatably requires gear that is perfectly set to work together along with you and your vision; sensor/back has to be perfectly registered to the camera body, focus screen has to be perfectly positioned, viewfinder diopter has to be perfectly set for your corrected or uncorrected vision depending on how you shoot and finally, you need to be able to read when focus is spot on, or have an AF system that does it for you. Get all that together and you have a chance, but getting all of that together is not a given as anybody who does it regularly can tell you.
I am fortunate in that my particular MF system is "there" for me (the Mamiya has a manual-focus "confirmation" light that is spot on with my current group of components) but it still requires paying strict attention during capture to get decent results. My current favorite lenses for this are the Mamiya manual focus 80mm f1.9, AF-D 150mm f2.8 and manual 200mm f2.8 APO; the latter having a portrait distance DoF so shallow as to be almost absurd. I used to use the Hassy 110mm f2 F lens and love the look, but the hard fact is I got similar enough results from the 80mm Mamiya, and then even shallower DoF's with the 150 and 200 lenses at f2.8.
Given the effort required with the MF outfit, I tend to now do shallow DoF more often with my DSLR system; with its micro-adjustable auto-focus for individual lenses I tend to nail my exact desired focus point with more regularity using the camera's AF. However, even with very fast f1.2 glass, the look isn't quite what the MF combo delivers --- and here's the real nit --- IMO it isn't just about the shallowness of DoF! I believe it's more about how the focus falls off from center toward edges that gives the fast MF lenses their rendering appeal. Of course then Bokeh factors in too, so it's a complicated soup to get that special look IMO...
gdwhalen
Why shoot wide open?
Because you don't ever want to walk into a situation where you can't get a shot. Obviously, you CAN'T get every shot but you certainly want to reduce the odds against you. I can think of dozens of reasons to shoot wide open. Dozens of reasons to shoot with as much DOF as possible. The world requires options.
Guy Mancuso
Administrator, Instructor
I agree and what most don't realize is 5.6 on a MF camera with DOF look is like 2.8 on a 35mm given the same focal length. Shooting people that DOF is so damn thin to start with even F11 you still get great Bokeh sometimes with the longer glass. Sure I love fast glass but i also want success rates as well.
gogopix
Subscriber
Yes, thanks Guy I am glad that even pros acknowledge that nailing the narrow DOF shot, though rewarding, is tough. And yes, the 35 vs MF difference must be remembered!
For some of us a long shot.
One thing Jack, does the Phase One have focus bracketing? that really helps. AF is fine, but it can never pick EXACTLY what the eye wants.
All the narrow DOF shots here are spot on in demonstarting the aesthetic basis of such shots. Thanks for sharing.
maybe I will practice :rolleyes:
Victor
Guy Mancuso
Victor many times I will use AF than switch to MF . One thing I do like about the Phase lenses is the manual focus clutch which I use a lot. The S2 uses the focusing ring once you touch it than your manual. Both are good but both have some limits as well
dougpeterson
I rarely shoot the Canon 50mm f/1.2 past f/1.8. It just draws such a beautiful image at those apertures.
Is it a bit technically soft? Sure. But for the images that I'm shooting at f/1.2-f/1.8 technical sharpness is pretty far down my priority list.
Doug Peterson (e-mail Me)
__________________
Phase One, Leaf, Cambo, Canon, Apple, Profoto, Eizo & More
Newsletter: Read Latest or Sign Up
RSS Feed: Subscribe
Buy Capture One at 10% off
