which 80mm Planar from these 3 lens are the best ?
proenca
Hi there,
I've pretty much narrowed down 3 bodies and each body comes as a package with a specific version of the 80mm Zeiss 2.8 lens . Now, which one is the best / most recent ?
I believe that , according to my research ( bear in my that my research on the V system started 4-5 days ago... :) ) this one seems to me being the oldest hence less desirable one :
After a small price jump we have this one , which seems less old than the previous ( and actually seems to be the body / lens combo that I will buy ) :
Last but not least, on the very brink of my budget is this one ( actually is a tad off ) but seems to be the newest ( or newer... ) of these three :
The "bang on" price is in the second version, its a 500CM . On the bad side of things, we have the latest one in the series, which is a 501CM ; I know ( and checked with the dealer ) that the 501CM does come with a improved finder but we are talking 699£ vs 999£ . Apart from the finder and minor body difference ( GDS, etc ) , is the lens difference ( from the second to the third ) justifies the price difference ?
By the way, the first of them all, its a 501C, the lens seems the oldest of all three , being the price in the middle ( 799£ ).
But the difference of a 501C vs 500CM ( to what I've read and I did a lot ! ) a 500CM seems perfectly fine for me.. so the difference here is the lens and funny enough the 500CM + lens combo here seems the best overall ( price wise )
carstenw
Yes, the first is a C, the second a CF and the third a CFE or CFi, most likely, although there was some overlap in lens body design as the models changed. I believe that the CF and CFE/CFi have the same T* coatings, but that the earlier model has an older coating design (a few C T* lenses do exist).
Also, the tolerances of the older model may be too loose in case you ever want to use a 2000/200-series body, so I would go for the CF in your place (F in CF means works with F cameras, i.e. focal plane shutter cameras, i.e. 2000/200-series). The 500C/M is just as good as the later bodies, with the exception of the gliding mirror system, which helps reduce vignetting for long lenses > 100mm.
You can read more about the features for each camera here:
http://www.hasselbladhistorical.eu/HS/HSTable.aspx
Guy Mancuso
Administrator, Instructor
I had the first one it's just okay. I just saw this package on e-bay and looks pretty good. Just a rough idea and don't know the seller but I would try and go for a newer body. From what I hear the 503 is pretty nice . I had all the old ones and frankly not sure i would buy them back but the 503 looks better, not sure it is. I don't know your budget either but if your going to add a DB later on I would try and get a later model just to be safe it is compatible. Maybe someone that knows Hassy better than I do but i remember reading something somewhere a old body would not work with a certain DB. Now my memory is the ****s but still something to explore.
This looks like a nice package
http://cgi.ebay.com/Hasselblad-503C...lm_Cameras?hash=item58835e8898#ht_6199wt_1167
These guy's have been on e-bay quite awhile but i never bought from them. They do ship worldwide also
s.agar
I wouldn't recommend the C lenses. The shutters (Synchro-compur) create problems more than the CF series (Prontor). CF series may have some other improvements as well. I had noticed a big difference in the 50mm lens, especially at the cormers. I don't know is 80mm is like that too.
CFi is the "improved" version of CF (they say). CFE is like the CF, with contacts (for 200 series), if I'm not mistaken. Cfi types are usually newer, and preferable. But CF is perfectly OK (hopefully if in good shape regarding the shutter ad the optics)
carstenw
I wouldn't buy the 503CX or CXi. They were the first C camera with the Palpas coating inside, which helped reduce internal reflection and thus increase contrast, but the Palpas coating gets old at some point and starts coming off. These cameras are old enough that it is a real risk, and it is not unheard of.
I can confirm that CFE/CFi lenses are newer and preferable, but in most cases they are optically identical, and only have other advantages, like the CFE with electronic contacts. They are significantly more expensive though, so maybe keep those in mind for later, in case you fall in love with the camera. CF is fine, C is not.
sinwen
I had the C and have the CFE.
IQ wise it is pretty much the same, what I liked in the C was the two notches giving you the depth of field, that was great.
Now it is a very old model with a greater chance to have mechanical problems, therefore I suggest the CFE.
Michel
archivue
the last one, isn't a CFE or CFi but a CB !
all the hassy 80 share the same opticall formulla except the CB.
The CB canno't be used with 200 bodies, but 500 only.
IQ wise, it's little bit better in the center, but a little bit softer in the angles... but nothing to worry about !
The best standard lens for hassy ? the 100 CFi anyway !
If you can afford a 501CM with is wider mirror (same as 503CW) i will go for it !
If money is concerns, then for film use, a 500CM and 80 CF is a good compromised !
I went myself with a 80CB, because with a digital back, i use the synchro all the time, and the plug on CFi / CFe / CB is really improved compare to CF... the internal baffling is supposed to be improved also...
Seascape
Any of the 500 series cameras will run forever if used appropriately, because all these are black bodies (that show wear easily) they appear to be in nice condition. I tend to look at the body/back interface surface, it has two raised ribs for light sealing, they are easily damaged if used in a "pro" situation and will show that use. The wear marks are not an issue, just an indication of the amount of hard use the camera may have taken.
The CB lens is an econo design (different lens configuration). optically the CF and C should be the same, with the CF being better mechanically.
If you are only using the 80mm lens the bigger mirror of the 501cm may be no real advantage over the 500cm.
If any of the bodies have an accumat focusing screen, they would be more desirable.
archivue
you can also shop for a 60 CB... same optic as the 60CFe without the F setting for 200 camera... a bargain on ebay !
Professional
Great thread because i bought 501CM last year only body, no lens, no film/digital back, but when i went to USA last October [3 months ago] i bought a film back for this camera and many film rolls, but now i am still confusing about the lens, should i go with CF or CFE or CFi, and i try hardly to save to buy at least one "New" completely lens for my 501CM, not sure which one, 50, 80, 40,...etc.
Mostly i love landscapes, but i want to do some street photography maybe and portraits, i have 180mm for my Mamiya RZ II, so i will avoid telephoto or long FL and i want to be in wide side at least.
carstenw
It will be hard to find a new lens now, and if you do, it will be very expensive. Hasselblad was always a very expensive brand. If you buy used in very good, near-new shape, you will save hundreds, if not thousands.
40-60mm, plus maybe 150mm or 180mm for details.
60-80mm, or 100mm.
and portraits
150-180mm, even 250mm.
Just buy the whole lineup :)
Well, you needs are very mixed :) I don't think that the Hasselblad makes that great a street camera, so why not start with a nice wide? The 50mm lenses are good and not too big or expensive, so that might be a nice start.
PSon
Hasselblad Carl Zeiss Planar 2.8/80 comes in:
1. C
2. C T*
3. CF T*
4. CB T* (improve internal flare with the new lens barrel material. The CB lens is not a popular lens due to the small limitation and thus the CB is in less demand and has the greatest value; CB lens share the same new barrel like the CFi and CFE lens which attenuate internal flare).
5. CFE T* (electronic couple for information when using with the Hasselblad H camera via the CF adapter and thus the most in demand and explain the price differences; improved internal flare control similar to the CB and CFi barrel)
Note: there is no CFi for the Hasselblad Carl Zeiss Planar T* 80mm lens.
To complete the Carl Zeiss Planar 80mm lens:
6. Rollei Planar HFT 2.8/80 PQ
7. Sinar M also has the Planar T* 2.8/80 ZH AF
Best Regards,
Son
wjlapier
This thread amongst the others is very imformative. I just bought a 501CM and want to eventually expand my lens selection. I'm a hobbyist so I have to take it a bit slow though.
Son or anyone else, could you give the break down on the portrait lenses carsten mentioned above. I'd be curious to know about sharpness and other qualities. The 50/4's as well.
Bill
T
tetsrfun
Take your time, do the research and buy from a reputable source. "V" series equipment is well built but service and repair can be expensive. So less expensive may not be so if it needs service or repair.
The "CF" lenses are probably the best bang for the buck considering age, shutter tech. and cost.
KEH.com is a good place to look at what is available on the used market, they have a large inventory. Probably not cost effective to buy for Europeans due to additional tax and duties.
Steve
T
tetsrfun
I have ~8 'blad lenses and the 50mm get the most time on the camera. A 50 CF is probably best compromise for cost and features. A 50 CF in ex cond will cost ~ $750USD while a 40mm CFE/CFI (a nice focal length) will be ~$2,500-3,500USD.
Steve
PSon
Bill,
1. Environmental Portrait lens - wide angle lens
a. Distagon T* 40mm CFE IF is the best in its class
b. Distagon T* 2.8/50 F and FE (you must use it with the focal plane shutter Hasselblad camera). This lens can focus extremely close and the older version can focus closer than the newer version but bigger and require a different shade. This lens has lovely bokeh as you can see from the work of Jim.
c. Distagon T* 60mm (CB is the best value but also CF. No CFE in this version. The CFi is too expensive but does not offer anything more in term of optics performance beside being the latest model). This lens is sharp and is popular in the Rollei mount as well as the Hasselblad mount. This lens control the distortion well so the subject looks more natural. If shooting people I prefer the 80mm lens if room is permit. However in cases where room is tight or you want to show the environment such as the stadium or orchestra you want the wider lens. Also if shooting with light it is important to understand your power and you must match it to the sun and in this case wider angle lens is also important such as group portrait.
d. Distagon T* 50mm CF, CFi (no CB and CFE model in this version). This lens is lighter than the F and FE 2.8/50 version so it is considered the most popular lens in wedding photography and it was my lens but whenever possible with enough power in my flash and space the 60mm and 80mm get the priority. People do not like to look fat and short so the 60 and 80mm are more natural to the eyes.
2. Close Portrait
a. 2.0/110 FE and F - Planar formula 110mm hand down the legendary lens where the length is not too long to create more natural look. In digital crop sensor this focal length is even better than film day. Unique lens that cannot be duplicated by other medium format lens.
b. 80mm (CF, CB, CFE, no CFi models) - Planar formula so it is very natural look. One of my sharpest half portrait ever taken. Group portrait is also the lens I prefer when I have space.
c. 4/150 (CF and CFi, no CB and CFE) - popular during film but slightly long for digital sensor.
d. 4/180 (CF, CFi and CFE, no CB) - extremely sharp but not popular for portrait. Too much compression which lead to flat look.
Best Regards
Son
archivue
i've found the Distagon T* 40mm CFE IF to be a very good and expensive lens but i just hate the distortion (moustache type)
In the 50, the CF Fle are much better than the simple CF... The CFi is even better
the 60 is better for lanscape than table top, more distortion than the 50... the 60CB is cheap and as good as the CFi
80 quite good but the 100 is the best, with nearly no distortion
The 120 macro is a good macro and table top lens, some used them for portrait also, but not perfect for infinity.
The 150 isn't the sharpest, but nice for portrait with film
The 180 is very sharp, but quite big.
Professional
Steve
Honestly, for that Hasselblad i want to have 3 lenses only, if not then only two, the three are: 50mm, 80mm, 150mm, the two will be 50 and 80 as i don't want to use only Hasselblad for everything, i still have Mamiya RZ which is with 180mm, so the long or telephoto is covered on one camera and as i said i love always to be in wide side of photography.
I was planning to buy 50mm or wide only new even expensive [i will buy once anyway], but for 80mm or 150mm i will go with good used one.
archivue
brand new 50 CFi cost 4000 $ excluding VAT, there's plenty of them in second hand from reputable dealer with warranty for 1000 to 2000$... i prefer to buy new also, but in that case, i will go for a second hand item !
with the price of the new 50 Cfi, you can buy a whole kit in second hand !
50 Cfi + 80 Cfe/i + 150 CF
