can you attach a crop of the affected area... 8bit TIF would be fine.Any ideas ?
yes !Is the moire in all 3 channels?
i used to think the same, but the "check print" cromalin© shows moiré as well !Without seeing the file it is difficult to really be of help, but regarding your last post: checking files at magnifications different than 25, 50, 75, 100% on PS introduces all sort of artifacts (moire & jagged edges are the first two that come to mind) - so I stopped using other magnifications altogether and editing became much easier and much faster, too. Just my .02, but if your file is fine at 100% then I'd say you're good.
If the file shows no moire at 100% then there is no moire in the file. Period. If you then see moire at other magnifications (including print previews, other programs etc) it is "screen moire" which is only an artifact of viewing the file on a monitor at non-100% settings.while at 100% it's fine, the problem is at 66,67 magnification in PSD... and we tried a cromalin© that shows moiré as well.
That's only a tiny thumbnail not the raw file:-(here is the link to upload the file...
Thanks for your Help !
http://dl.free.fr/getfile.pl?file=/JcHSYMkm
password : moire
that's the crop where there is moiré in the file...That's only a tiny thumbnail not the raw file:-(
