Hmm. I'd be more worried, personally, about the DB, here. Salt water and electronics to not mix well at all. It might power up after it dries out, but the corrosion will soon render everything quite useless. Fortunately for me, my most costly loss to the sea was a cell phone; after lengthily letting it dry out, I popped it open, only to see evident signs of corrosion all over the PCB. If you actually got seawater in your DB. . . well, good luck to you.
On a different note, the GT3530LS with a RRS BH-55 head is what I'd recommend. Perhaps a system of clips and carabiners with strong cable as to securely fasten the setup to your body, as to prevent the occurrence from happening again, too.
See: http://www.munchkin.com/products/detail.html?section=pr...ries&ID=10011&pID=1184
