Williamson Images
I'll add that I shoot with the Cambo wide RS and both the new 28mm Super Digitar and 60mm apo. I use the Leaf Aptus II 10 - as most of you will know 56mp - is a similar Dalsa sensor to the Phase IQ 160 that Guy has. I have had great results. I use the 28mm for about 50% of my architecture work and it works nicely with the LCC on capture one software. And yes, use shifts and rise with it. I have had no issues with my 60mb back so hopefully, there are still options for many shooters and we will avoid "the sky is falling threads." I can get away with 10-11mm of shift without losing color saturation after fixing with LCC. Any more than this like up to the 17mm limit, and the edge of the frame loses most of your color saturation and looks somewhat monochromatic. Green leaves look brown. Blue sky looks like you desaturated 30 points. Yellow painted interiors go to neutral beiges. So hopefully you can know this ahead of time and compose your images to work with this if you need more movements. I find the sharpness of the lens like going from canon wide's to Leica M wide glass. It is like the same night and day from my zeiss 35mm lens on the contax to the schneider 28mm super Digitar. And the zeiss 35 is outstanding. So there you go. The 60mm is stellar no matter what you do to it.
I won't be shifting the 28mm to the extremes unless I am looking for a black and white image. Most of my work with the 28 falls in the zero to 10mm of rise anyway where it excels nicely (with my back.).
Hopefully in the next few weeks, guy and I can do an abbreviated but similar test and involve Doug with the 28mm on the phase iq160 to see if it has similar results to what I am seeing on my Leaf.
Robb Williamson
Robb Williamson
