Page 57 of 83 FirstFirst ... 7 47 55 56 57 58 59 67 ... LastLast
Results 2,801 to 2,850 of 4111
Thread: Technical Camera Images
  1. #2801
    Jan 2012
    1,129
    Re: Technical Camera Images
    Canon TS-E 17mm, FPS, IQ250
    f/11, 5 seconds, ISO400
    16:9 crop for a reason
    Likes 23 Member(s) liked this post
  2. #2802
    Member jerryreed's Avatar
    Essex, CT
    70
    Quote Originally Posted by danlindberg View Post
    Jerry, thanks for your kind words First of all, The image above was indeed shot with the TC. I do like the 2:1 pano ratio and look for those images frequently and I both flatstitch with the MAX and make nodal stitches with the SWA or TC. However, I am not ruling out a one shot and crop out for a 2:1 in post. With the Aptus II 5 I did not do this because I thought I lost too much info, but with the Credo 60 I must admit that a native cropped out 2:1 is 76 cm wide @ 300dpi. I have printed 2 metre wide canvases from a file like that and the print was impressive with great detail and resolution. There is no hesitation from me 'planning' a 2:1 from one exposure.
    Now, I can see that people can easily look at my byline and think that is totally excessive and only gives bragging rights having 4 bodies. Truth is, I use them all, all the time. The TC is absolutely brilliant if I want tiny. It happens often, in fact exactly this with the image you refer to, that I take out the Alpa TC, the Credo and unscrew the centrefilter of the SK 35 XL and use it as a fixed f8. This is truly a small and light package and has so, so, so much power in terms of IQ. I put the circular bubble on top, a soft release and then I shoot from the hip and with the bubble I know when I'm level, I know the field of view by heart and I can ever so slightly point the cam up a bit or down a bit. It just works.
    The SWA is the perfect companion if you walking in a city. Again if I use the 35 (then with centrefilter) I often put on a default of 5-6mm rise and with the sportsfinder and cam at eyelevel you get spot with just about right foreground and buildings across the street with paralell lines. The SWA is quite a bit smaller and lighter compared to the MAX which means this is the body I choose if I go hiking. It is still compact and light and most of the images are shot zeroed, but with the possibility to shift when I need to. Personally the SWA is also the most beautiful Alpa and so well balanced with the excellent grips on both sides.
    The MAX is my choice on all architectural assignments. 95% of all interiors are shot with the Alpa Max and the Schneider 28 XL. I simply love this setup and the only, and I mean only, thing I don't like is the dense centrefilter for the 28. The vignetting issue is to my work far more disturbing than the colourcast. With the Credo 60 I go 8mm and can easily correct, but the centrefilter steals over 2 stops and still does not effectively cancel out vignetting completely at f8. Anyway, without Alpa Max my bread and butter work would be more difficult. For instance shooting into bathrooms with large mirrors I frequently have horisontal shift as well as rise or fall.
    The FPS is ofcourse übercool with endless possibilities. If, and this is a big IF, the upcoming Schneider PC 28 tilt/shift is as good as the tech lenses, then I could get by with FPS as only body. But I have doubts that this will be the case. I have compared FPS + Tse24 and Max + SK 28 XL and the latter wins handsdown. The dream would be the FPS with small integrated tilt/shift adaptors that could be used with wide tech lenses. A lot to ask for and maybe completely impossible, but I guess one can always wish.....
    Funny thing is...if I didn't have any Alpa at all. Starting from scratch. I would most probably buy the STC.....
    Dan,
    Thank you for your comprehensive and valuable sharing of experiences with ALPA in your interior and exterior work. Your work illustrates what is possible at the highest levels of professional photography.
    Jerry
    Jerry Reed
    http://www.jerryreed.net
  3. #2803
    Jul 2013
    27
    Quote Originally Posted by miketclaw View Post
    Pentax 645D with Hasselblad FE 150mm / F2.8
  4. #2804
    Mar 2012
    Hamburg/Beijing
    219
    6
    i dont know, there is something missing that would make the image pop out
  5. #2805
    Jan 2012
    1,129
    Quote Originally Posted by drevil View Post
    It's a test frame for a timelapse (hence 16:9). Pretty much untouched.
    The finished article will pop
  6. #2806
    Senior Member dchew's Avatar
    Feb 2011
    Northeast Ohio
    858
    Nice Alpa home page Gerald!
    ALPA of Switzerland - Manufacturers of remarkable cameras - Home
    Dave
    davechewphotography.com
  7. #2807
    Jan 2012
    1,129
    Achromatic+
    70HR
    ALPA Max
    Lee #87
    (This is the full frame of the cropped image I posted in the B&W thread.)
  8. #2808
    Jun 2010
    Switzerland
    50
    Hartblei HCam B1 - P45+ - Samyang 85mm f1.4 -wide open - ooc
    visit me at www.kabraxis.de or http://www.flickr.com/photos/kabraxis/
    My ebay stuff
  9. #2809
    Aug 2012
    990
    Damn, now I want one of those Achromatic's too!!
    Peter
    Achromatic+
    70HR
    ALPA Max
    Lee #87
    Peter
    My website
  10. #2810
    Jul 2010
    604
    Alpa Max
    90HR
    34mm Tilt Adapter
    17mm Tilt Adapter
    P65+
    Alpa Max
    90HR
    34mm Tilt Adapter
    17mm Tilt Adapter
    P65+
    Alpa Max
    90HR
    17mm Tilt Adapter x2
    P65+
    www.dossantoslemone.com
  11. #2811
    Aug 2012
    Singapore
    32
    Are these photos from Singapore?
  12. #2812
    Senior Member rayyen's Avatar
    May 2011
    Hong Kong
    538
    this is stunning!!!
    Leica | Angenieux | Alpa | Rodenstock | Schneider | Phase One
    www.raymondchak.com
  13. #2813
    Jan 2012
    1,129
    Quote Originally Posted by rayyen View Post
    this is stunning!!!
    Cheers
    I should again stress that this was just a test shot, primarily for checking composition - I've barely touched it processing wise.
    The original set of RAW files (same shot at all ISO's on the IQ250) are linked to in this thread if you're interested in checking them out.
    Kind regards,
    Gerald.
  14. #2814
    May 2011
    Hong Kong
    538
    [IMG]<a href="https://www.flickr.com/photos/rayyen/13483670193" title="CF004801-3 by raymond chak, on Flickr"><img src="https://farm8.staticflickr.com/7079/13483670193_531455a5dd.jpg" width="375" height="500" alt="CF004801-3"></a>[/IMG]
    Shipwreck at Cheung Chau, Hong Kong
    www.raymondchak.com
  15. #2815
    Jan 2011
    Palo Alto, CA
    615
    El Capitan in a very dry Yosemite Valley...
    Alpa MAX, HR 32 Rodenstock 17SB, tilt and flavored to taste.
    www.rgaphoto.com
    Likes 9 Member(s) liked this post
  16. #2816
    Jan 2011
    Palo Alto, CA
    615
    Behind The Tree
    Alpa MAX, 80mm SK Digitar SB34, IQ160, side tilt
    www.rgaphoto.com
  17. #2817
    Senior Member darr's Avatar
    Jan 2009
    North Florida
    865
    Pincushions & Lace
    ALPA Max + 120mm Macro + 17mm Adapter + P45
    Likes 22 Member(s) liked this post
  18. #2818
    May 2011
    Hong Kong
    538
    Shipwreck in Cheung Chau, Hong Kong
    by Alpa Max - HR32 - IQ260
    www.raymondchak.com
    Likes 26 Member(s) liked this post
  19. #2819
    Aug 2012
    Shanghai / Miami
    552
    124
    Quote Originally Posted by darr View Post
    Pincushions & Lace
    This is really nice!!!!!!!!!!!!!!
    Philip
    www.pg-pg.com
  20. #2820
    Jan 2009
    North Florida
    865
    Quote Originally Posted by alajuela View Post
    Thank you Philip! I do enjoy an unusual flower in front of my camera.
  21. #2821
    Aug 2008
    165
    Ray,
    The detail in this picture is astounding!!
    I love this- makes me want to go out and buy an Alpa camera and 32 HR tight now...
    Likes 7 Member(s) liked this post
  22. #2822
    Jul 2013
    27
    Quote Originally Posted by MikeHlop View Post
    Its in Hong Kong.
  23. #2823
    Aug 2008
    165
    I meant to say 'right now' !!
  24. #2824
    May 2011
    Hong Kong
    538
    Question Re: Technical Camera Images
    Quote Originally Posted by Smoothjazz View Post
    Go Go Go!!!
    www.raymondchak.com
  25. #2825
    Irvine, CA
    229
    24
  26. #2826
    Apr 2008
    Hong Kong
    487
    Just back from Iceland.
    Iceland 2014 by yatlee, on Flickr
    Yat
    www.flickr.com/yatlee
    Likes 31 Member(s) liked this post
  27. #2827
    Jul 2013
    27
    Old pentax 645D Photo.
    Hasselblad FE 250mm F4.
  28. #2828
    Jul 2013
    27
    One more 645D.
    Hasselblad FE 150mm F2.8
  29. #2829
    Senior Member danlindberg's Avatar
    Aug 2010
    Spain & Sweden
    1,161
    Alhambra - Granada.
    Tripods not allowed and walking through with a guide with time pressure. Hundreds of tourists just about everywhere and ropes and signs where ever you turn. I nightmare for my normal slow working pace and tripodshooting.
    The frustrating thing was that there are countless of stunning images to be had - IF they would have let me in there alone.
    From three hours of rushing around I only have three or maybe four images from a place where I could 'see' hundreds....
    Oh well, this is one of the very few I was happy with. Handheld, 1/60, f8, iso 100, 7mm rise. And I had about 1/2 a second to expose when nobody was within the comp.
    Alpa FPS • MAX • TC | Alpagon 32Hr | Helvetar 75 | Schneider 120N | Leaf Aptus II 5 • Leaf Credo 60 | www.danlindberg.com
    Likes 27 Member(s) liked this post
  30. #2830
    Apr 2008
    Hong Kong
    487
    A cloudy morning at Vik
    Yat
    Likes 14 Member(s) liked this post
  31. #2831
    Aug 2010
    Spain & Sweden
    1,161
    A sample image from a new art series from me. Actually shot with the fat pixel back Aptus II 5 by choice.
    Likes 17 Member(s) liked this post
  32. #2832
    Manchester/Jerusalem
    2,652
    290
    Alhambra - Granada.
    Rarely has half a second been better timed or spent. I'd have killed for an image like that when I had all the time in the world!
  33. #2833
    Shashin's Avatar
    May 2011
    Maine, USA
    4,224
    133
    Dan, it is funny, I have just been reading about 19th century photography and the Pictorial photographers and composite printing. And now, in the beginning of the 21st century, we have this early technique and aesthetic brought back to life (again). Well done.
    Will
    http://www.hakusancreation.com
  34. #2834
    Jul 2013
    27
    Mamiya DF+ Credo 40 35mm
  35. #2835
    Aug 2010
    Spain & Sweden
    1,161
    Thank you very much Ben, fantastic compliment! Truth is, I was frustrated because I saw incredible light and scenes everywhere but had no chance to 'work' in the touristic circumstance. But, this one actually gave me 'some' satisfaction that I could walk away with atleast one good one.
    So very true! this kind of aesthetic has been around for a very very long time and far from finding new ways of artistic expressions, but it really appeals to me. Timelessness I believe is a good thing. Thanks!
  36. #2836
    2,652
    290
    Any chance you can go during a quieter season, when it's a lot earlier or too hot for tourists, etc? Shooting in Jerusalem as you can imagine I've often had to deal with exactly the same things, often it helps to get the timing right even if it means waiting 6 months until you can get a clear scene and some peace and quiet.
  37. #2837
    Shashin's Avatar
    May 2011
    Maine, USA
    4,224
    133
    But isn't this what the artist does. It isn't finding something new, it is just building on the old and putting it together in new and interesting ways. And I prefer your interpretation of this craft to the Victorians. Although, they were darn dedicated--36 images and six weeks of work:
    http://commons.wikimedia.org/wiki/Fi...ys_of_life.jpg
  38. #2838
    Aug 2010
    Spain & Sweden
    1,161
    Unfortunately no such thing. It is incredibly popular and if it is open for the general public, there are numerous busloads every opening hour. Nowadays you must have booked a guide to enter most of the buildings to be able to see them inside. If you have no guide, then you are pretty restricted and on top the guides have timeschedules to follow.
    There is only one way - to get assigned by Alhambra themselves! I am actually looking into this possibility and I have an 'inside-guy' that I am going to contact to see what could be done. There are reference images to be had in there.....
  39. #2839
    Aug 2010
    Spain & Sweden
    1,161
    I bow to that
  40. #2840
    Aug 2010
    Spain & Sweden
    1,161
    Lines & shadows
    Likes 12 Member(s) liked this post
  41. #2841
    Mar 2012
    Sweden
    1,531
    Ice and snowmobile track.
    The image was shot a couple of days ago. I shot it perpendicularly straight on without any shifting or tilting, so it's not so much a demonstration of tech cam features. I'm very pleased with the image though.
    Linhof Techno, Leaf Aptus 75, Scheider Digitar 47XL at f/16.
    Normally I shoot these type of subjects with longer lens than the 47XL (the SK72 is my favourite) as I don't want any perspective effects in them, but I needed to get the structures at the right scale and still reach over the camera to focus and shoot, so I needed to use a wider lens.
  42. #2842
    Feb 2011
    Eads, Tennessee
    920
    First post in this thread..... A once very stately entrance in Venice.
    Victor
    Alpa STC Schneider 100mm Digitar Phase IQ180
    Likes 10 Member(s) liked this post
  43. #2843
    May 2011
    Hong Kong
    538
    International Finance Center, Hong Kong
    Alpa Max - HR90 - IQ260
    Waiting for more than 6 months, finally it arrived : )
    My Alpagon HR90 ;D
    www.raymondchak.com
  44. #2844
    Mar 2012
    Sweden
    1,531
    When I saw this rock the other day sticking out of the snow I immediately knew what image I wanted, an isolated rock on a white backgorund, that would look artificial but when you look carefully you see that the surrounding white is actually real snow. The lower contrast of the bright snow enhances the effect. The "artificial" look is also enhanced by the special structure of the marble rock.
    Unfortunately nature was not as kind as I needed to fulfill my "inner image". I could not fully isolate my rock, but got some additional rock in the upper right corner. What to do? Drop the idea, or fake it?
    I've attached the original, and an edited version which shows my idea. I generally don't edit my images (remove things), but in this case I might do an exception. If you tell the audience what you've done I think it's okay.
    Shot with Linhof Techno, SK90 and Aptus 75.
  45. #2845
    Sep 2013
    Munich, Germany
    210
    Torger,
    I think it's ok to manipulate the image and clone out things, if you're honest with the viewer. Another way to make this kind of manipulation more "acceptable" is to make even more modifications - like turn it into B/W, bump the contrast. That way, the picture becomes more "artsy" and one expects it to be less a representation of "reality".
  46. #2846
    Apr 2008
    Hong Kong
    487
    Another one from Iceland trip.
    The clam of iceberg by By Yat Lee, on Flickr
    Yat
    Likes 13 Member(s) liked this post
  47. #2847
  48. #2848
    Apr 2008
    Hong Kong
    487
    Sunrise at Vik
    Sunrise at Vik by By Yat Lee, on Flickr
    Yat
  49. #2849
    Apr 2008
    Hong Kong
    487
    Snow covered Grundarfjörður
    Snow covered Grundarfjörður by By Yat Lee, on Flickr
    Yat
  50. #2850
