If Steve isn't worried then I'd go with the gaffers tape and try to forget about it. He knows his stuff.Steve Hendrix sent me a note today re this slight looseness in my CFV back on the 503CWD. He checked a CFV back there at PPR on a 503CX and it did the same thing.
Hey DougIf Steve isn't worried then I'd go with the gaffers tape and try to forget about it. He knows his stuff.
Doug Peterson
Capture Integration, Phase One Dealer
Personal Portfolio
That troubled me also when I got the camera/CFV/40mm lens back from Hasselblad service last week. I understand that they had to make some adjustments to the camera, back or lens (or maybe all 3) in order to get the 40mm lens to work with the 503CWD body and CFV back properly. I assumed that this adjustment in someway just slightly lessened the degree to which the back is snugged up to the camera by those two prongs/hooks at the top. I am sure I would have noticed the metallic clicking noise during the week I used the camera, before I sent it into service. When I pulled it out of the box from Hasselblad service and went to put it on a tripod to test the 40mm & camera, I noticed the clicking sound almost immediately.Gary,
What wonders me in your case, is that you had a body with back which seemed to match perfectly. And then you get it back and it moves. This seems odd to me and should not be the case.
Best regards,
Thierry
Every 200 series body I've used with the CFV (3) has been tight as can be. Every 503CW and 501CM showed some play with the CFV ... but not very much. So sending in the 503CW camera for an exchange won't guarantee an air tight fit.since it seems the common out of whack element is the 503 body, i would ask for another one. for over $10k, a misfit is unacceptable, and they certainly are able to get it right on most bodies.
He knows the same amount. I'm just more willing to point it out now .Hey Doug
Does Steve know more now that he is a Phase rep? LOL
Woody
I'm almost ready to follow Steve Hendrix's example and jump to Phase One....... :bugeyes:He knows the same amount. I'm just more willing to point it out now .
Doug Peterson
GaryI'm almost ready to follow Steve Hendrix's example and jump to Phase One....... :bugeyes:
No, no.....just kidding. The 503CWD is a great camera. Can't go wrong with 9 micron photosites and Zeiss optics, right? :thumbs:
Gary Benson
Eagle River, Alaska
Learning to relax and not sweat the small stuff.......
Gary, the back should not move at all. I use a 503CW with a Phase one P20 and the back fits perfectly. It doesn't move a single milimeter. That's the way it must be.
Certainly, Hasselblad is doing you a really bad service. So send the camera back to them so they provide you with what you've paid for.
I think I could write a whole article about how bad Hassselblad is doing certain things but I'll stop here.
I won't tell you what to do but if you're still in the position of being able to return the kit I'd do it and I'd switch to phase. I was in the same stage when chosing a square back and I went with Phase One because their realibility. This system is rock solid and stable.
Just my opinion...
/Samuel
hi Samuel,
with all due respect (and we know and respect each other), I don't think that this is a reason to switch to another brand.
And to the contrary to what you are experiencing with your combo, there are differences between the different MF bodies, being it Hasselblad or others, from a same model: I have experienced it x-times, with different MF body brands, and with different back brands. Sometimes it did fit perfectly, sometimes too tight, and then more than often wobbling a bit.
This is actually not due to the back, but to the camera body: all backs are made under very tight tolerances, up to 1/1000th of a mm, concerning adaption and mechanical parts. MF bodies which were made for film have much less tighter tolerances.
As I said, this can be adjusted, respectively corrected. I would hope that Hasselblad, if contacted because of such, would be flexible enough to either fix this or exchange the 503 body.
Best regards,
Thierry
Good response Theirry. I have experienced exactly the same thing with different backs and different cameras.hi Samuel,
Best regards,
Thierry
Man, if it's "moving around" that much I'd express that sucker back to Hasselblad immediately.If a digital back is moving around on a body, then doesn't it also have the possiblity of causing more then normal wear on the Camera body and the Back? I would think that would be something to consider as well.
Jason
