dougpeterson
Bias alert: see my signature. My company is a value added dealer of Phase, Leaf, and Mamiya products.Honestly, based on the work you are doing, I would say stick with 35mm digital. The amount of manipulation you are doing to the files is going to eliminate any of the more subtle tonality and bit depth advantages (though you may have more manipulation headroom in your files), you are going to give up the very wide angles and zooms that you probably find quite useful. A
This statement profoundly confuses me.
In my experience this is the exact style that benefits the most from the additional bit depth, tonal smoothness of the original file, crisp pixels at 100% and additional dynamic range.
Retouching, especially stylistic retouching that use curves, large radius USM (local contrast), local dodge and burn, HDR style effects, and saturation punches draw considerably on the quality of the original file. A high-end dSLR and a digital back are visibly different at 100% at base ISO, but it's in the grand scheme of things pretty subtle - where the difference really comes out in my experience is precisely when you start doing this sort of retouching. Smooth surfaces start to break up into posterized sections, skin develops "color breaks" along the cheeks or along points of highlight to shadow transition, subtle shadow noise becomes obnoxiously apparent.
From everything I read and see here this is an ideal application for a digital back. Slower more methodical work that will be reproduced large and benefits from a high quality starting file which will last deep into post-processing.
A tech camera would afford you supurb super wide angles, high-speed flash sync with your studio strobes, and great image quality if paired with any decent digital back.
A Pre-Owned Phase One, Leaf, or Mamiya digital back rented or purchased may fit into your budget and I'd suggest you add those brands of back into your search (very self-serving suggestion since our company - to be up front - sells all three, but not Hasselblad). I'd also suggest that there are several companies that make tech cameras such as Cambo, Arca Swiss, Horseman, and Linhof (again self serving as Alpa is the only tech camera we don't sell). In particular the Cambo Compact is a very affordable no-movement tech camera that would work great with a 23 or 24mm.
You'll want to test out Phocus if you're considering Hassleblad and Capture One if you're considering Leaf, Mamiya, or Phase One. Capture One will have the benifit of also working fully (e.g. tethered with camera controls from an iPad/iphone, in-frame HDR) with your Nikon as a backup or second camera along with a full feature set like perspective correction, focus masking, local adjustments, overlay preview (in case you ever need to place text/design over top the image - e.g. for a magazine cover), direct wireless control of Profoto Air strobes etc. It's also an industry standard that many assistants/digital-techs know well. To get the most out of any digital back you really want to be facile and comfortable with that manufacturer's software - doubly so if you ever want to tether (which with a technical camera will be very likely on some, if not all jobs). You mentioned you can get a "good deal" to rent the Hassy back; I'd posit that a low price for an item that isn't the best solution for your needs isn't a "good deal". It's better in my experience to start off asking "what back will be best for me" and then look for a good deal to rent or buy it rather than finding the lowest priced rental/purchases available and asking if you can make it work for you. It may well be a Hassy back and an Alpa (they make great products with advantages and disadvantages); I'm just suggesting you find that out for yourself rather than starting with what happens to be on the plate of your local place you have a deal with. You will after all be spending a lot of time with the camera, back, lenses, hardware, and software and your time is worth a lot!
More info about Capture One
Doug Peterson (e-mail Me)
__________________
Phase One Partner of the Year
Newsletter | RSS Feed
Buy Capture One 6 at 10% off
