Hasselblad V to Mamiya adapter
Paul Spinnler
Hi guys,
just a quick question for those who use an adapter: There's no problem using this adapter with the newer Phase One DF cameras, right?
Kind regards
Paul
Paul,
It's fine. Limitations (same as any other mamiya or older mamiya manual lenses) are stop down manual metering.
Regards
Paul
FredBGG
Not Available
You can modify hasselblad lenses and use a dual shutter release to stop down and shoot.
One cable stops down the lens and the second cable fires the shutter in the camera.
arionelli
That's interesting Fred...can you desribe how/direct me to some more info re that by any chance? Have you any such modified lenses?
FredBGG
Not Available
I had a modified Hasselblad 150 2.8 that I had modified.
What you need to do is have a hole drilled in the right spot
so that the cable release moves the depth of field preview mechanism to shut down the iris.
You then need a Mamiya RZ double cable release and inset the "early" cable to the lens and the "later" cable into the camera.
Unfortunatly the lens was stolen so I can take a photo of it...
