Lens problem ID 27:1
D
drmytan
Just bought my HC 50II mm in Dec last year. Pretty new and hardly use!
Recently l found out problem with this lens (attached images). I contacted the Hasselblad guy and he asked me to return for checking or service or whatever. OMG this is a new lens and my camera H4D31 is also pretty new.
What's wrong with the lens?
What are they going to do to it? To open ii up and screw it back!
Urgently need advise before sending it to the factory
D
drmytan
Try turning the camera off, remove battery, and re-insert. remove and mount lens again, power on.
Have tried dozens of times. It only happened after a few shots maybe 5-10min. Then after detaching and mounting back the lens, it will be fine for further few minutes then the problem will repeat. Sick of it ! :mad::mad::mad:
stngoldberg
I had a similar problem on my 120 Hasselblad Macro-H series. Had to send it back to Hasselblad in New Jersey for repair. They returned it within a few days and it has been perfect since. I realize that the service may not be as rapid from Malaysia, but my guess is the lens needs repair
Stanley
D
drmytan
Stanley
Hi!
Exactly what will they do to it? Just clean up the contact or plug in and change data through computer .. or dismantle or disassemble?? :angry:
Thank Stanley
stngoldberg
they didn't tell me what they did, but they will tell you if you ask-the hasselblad people have been very honest and informative with me
Stanley
chiek
Your shutter condition is not good. Contact hasselblad a/s.
I have similar experience with my 2nd hc50-110.
Finally, shutter changed to refurb. Shutter
Landscapelover
Senior Subscriber Member
I had the same problem with my 35-90mm which was 3-4 months old. I sent the lens back to be fixed by the Hasselblad USA. It's worked great since.
I'd recommend you to send the lens back to the company.
