Don Libby
There's been question regarding shifting and tilts using the new hood and while I don't have a tilt lensboard I figured I could at least answer the question of shifting, besides I need to see this for myself as I'll soon be using it in Jackson Hole.
Deciding to try an actual test using what could be real life conditions (at least for me) I shot from near top of a hill overlooking the "scene" below. If I close my eye real tight I can almost imagine tress, river and snow capped mountains. Sorry, got a little carried away there....
Back to the test. The camera is a Cambo WRS1000 coupled to the P65+ and using a Schneider 72mm lens. The ISO is 50 f/11 at 1/250. The images were captured using the following format: First row: Centered 10mm down, 15mm left, 15mm right, Second row, Centered, 15mm left, 15mm right.; Top row Centered 10mm up, 15mm left, and 15mm right. Total of nine-images captured. Each row was processed into their own individual panoramas for show and tell and finally all nine-images processed into one-image.
Included here are all the images. No processing has been done other than to open in C1Pro to save into a Photoshop file then opened in Cs5 to use Photomerge. All images were later downsized and save for internet Jpegs.
First the individual images:
Centered - no movements
Centered with 15mm right shift
Centered with 15mm left shift
Centered, 10mm down
Down 10mm, shifted 15mm left
Down 10mm, shifted 15mm right
Moved 10mm up, Centered
Moved 10mm up, 15mm left. This is the first indication of trouble in the upper left corner.
Moved 10mm up, 15mm right. Again look at the upper right corner.
And the rows:
All 3-images merged for the bottom row.
All 3- images merged for the center row
All 3-images merged for the top row
Final image with all 9-images merged
There are some slight concerns on the upper corners however I feel that processing can fix most of them.
The shoot took place outside of Tucson, mid morning facing Southeast with the Sun off my left shoulder.
Don
Centered, 10mm down
And the rows:
Don
