Stuart Richardson
P.S. Have a look at this...it is the general idea: JetMounter 44 - Mount An Image to a Substrate - YouTube
You can do it with any sort of rigid substrate...aluminum, foam, pvc etc. You can also laminate it with a UV coating if you get the proper roll laminate. Alcan sells some suitable substrates...you can see them here: http://www.display.3acomposites.com/index.html?&L=1
