rollei 6008 integral and P20??
D
det05
in order for my rollei 6008i to work with the db20p version of the p20 back made for its new sibling 6008 AF, must I sent it for modification to unlock some cache or wire up something?
i read here that the 6008i has to work with cables for the db20p, is it true?
irakly
i do not know the inner works, but one of my students had his combination, and it had horrible problems. every other shot was a malfunction: the back beeped, a red light would go off, and an image would be all magenta with partially scrambled pixels. then i saw the same thing with a 6008AF. it was for sure an issue with bodies, as in the second instance everything went fine when the body was replaced with a later serial number version.
My 6008i does this with my Imacon 132C if I try to use the DIN cable. I switched to using PC sync and haven't had any problems since.
My guess is live view won't work (with the 132C) without the DIN cable, but it was pretty rubbish on this back anyway...
Geoff
Some time ago, a conversation with the factory (via phone) left the follwing impression: that in general the earlier 6008i's would not interface seamlessly with the dp20's, but the later 6008i's would. On the other hand, the change was not identified by a particular moment, or serial number - but rather the cameras should be tested for this.
This suggested some internal change to the electronics that may have been introduced at a moment, in some cameras, and not in others. The best way to avoid this (I think) is to use the 6008AF as the base for the dp20, or better yet, to get the kit of camera and back together. The kit would have been aligned at the factory, and should perform well.
Geoff
(first post at GetDPI)
D
det05
thanks Geoff, a great help in ur first post.
guess i may have to forego this setup.
Graham Mitchell
A Sinar back will work on any of the 6008s without modification, and you can get a larger sensor as well. With the price of the new e54 down to €6K, refurbished e22s and e54s are really affordable.
Geoff
thanks for the welcoming.
As to the back on the older 6008i, another option is simply to find another 6008i, or 6008AF. Not quite pricey in today's market, altho Graham is right about the Sinar back as well.
Just getting a 6008AF with dp20 back, and will report back any issues. Its been said that some 6008AF's that were not bundled at the factory with the dp20 may need a minor elec adjustment to combine the "wake up" call for both camera and back. This can be done in NJ, not major.
The issue of all the bits working together is always a problem. Getting all those hard drives to be asleep and awake when they are supposed to be is kind of like putting kids to bed. Sometimes they behave, and sometimes not!
EH21
You need a resister added to the camera in order to avoid the back going to sleep which it will do if the camera goes to sleep without the mod. It's a simple modification and can be done by Rollei Hensel service in NJ, or probably your local Rollei service. You can also shoot this combination keeping in mind that the camera goes to sleep at 40 sec in single point metering and 4mins in multipoint metering modes. If you are shooting more frequently than the 40 sec or 4 mins then you will not experience the back going to sleep and getting the double shot error on the back. You can also make a wake up cable for the back, but probably easier to just get the camera serviced.
