Kumar, is this a problem only with the 120 or also with other lenses? Does it 'reset' if you detach the digital back and put it on again? It is possible that the shutter in the lens is not opening which may be a camera related problem and not primarily due to the lens. I had something similar happen to me.Hi..
I recently bought a Mamiya 120mm F4 macro lens. Its a D version and for a few days it worked fine. And after that it starting showing errors. While pressing the trigger there is a strange noise from the cam and the aperture remains closed. I tried removing the lens, still the aperture remain closed. reconnected, but still error shows. After sometime, by removing the lens and battery, it finally went back to the original state. Again after some more clicks the same condition repeats. Is it a common problem for this lens? If yes, for macro purpose, which other version is better? This was an optically superb lens. I cannot afford the new 120mm LS.
Attaching the image of the lens.
https://drive.google.com/file/d/0B7J2h1_o7sEReS1qbmhheDZYVEk/view?usp=sharing
Thanks in advance.
Might this topic be better put in its own, better-titled thread (than tacked onto a 2014 one!)?Hi..
Thanks in advance.
Just a shot into the dark. But it might be a firmware issue. The 120 macro may be a firmware carrying lens. For sure the DF+ has firmware. You would need to check with a phase one dealer as Mamiya and Phase One are one company.Hi..
Thanks in advance.
Thanks. Yes This problem is only with 120mm Macro MF D lens. And this is the only focal plane lens I have. Others are leaf shutter lenses. I have to find out that it's a Camera problem or Lens problem.Kumar, is this a problem only with the 120 or also with other lenses? Does it 'reset' if you detach the digital back and put it on again? It is possible that the shutter in the lens is not opening which may be a camera related problem and not primarily due to the lens. I had something similar happen to me.
Thanks Paul. My DF+ is holding the latest firmware update. 2.31.0 and the 120mm Macro firmware is 0.30.0, which I do not know the latest or not. I am using both kinds of batteries. I have a new Li-on battery too. But the problem exist in that too. Anyway today I'm planning to check this lens in my friend's DF body and his macro lens in mine. Thanks once again for the reply.Just a shot into the dark. But it might be a firmware issue. The 120 macro may be a firmware carrying lens. For sure the DF+ has firmware. You would need to check with a phase one dealer as Mamiya and Phase One are one company.
If the DF+ needs a more current firmware. You need the V grip to upgrade lens or camera firmware.
I know for a fact early versions of the 28mm and DF Had a similar issue which was resolved with firmware on the lens.
It also may be batteries in the DF+. Are you using the AA holder or the Lion pack? The lion pack is much more dependable.
Paul C
Kumar, does the image come out absolutely black, like there was no exposure, despite the camera making the right sounds? Then it may be that the shutter in the camera does not open with this particular lens. Best way, as you said is to test the lens with another DF body.Thanks. Yes This problem is only with 120mm Macro MF D lens. And this is the only focal plane lens I have. Others are leaf shutter lenses. I have to find out that it's a Camera problem or Lens problem.
