Not sure with hand held that the difference in sharpness will matter... And with good retina like display, shooting more wide open at faster shutter speeds will be terrific: wider open now.Paul - below is the post from Josh Booth regarding the 1.7 update for Capture Pilot:
https://captureintegration.com/capture-pilot-1-7-released-2/
And the 35mm lens is the 35mm HR, as Doug noted, which has the (somewhat) restrictive 70mm image circle, the 35mm APO Sironar has a larger (105mm) image circle, but does not equal the optical performance of the 35 HR.
Steve Hendrix
Capture Integration
So when do you think they will develope a teathering option for the IQ1's and the iPhone? :ROTFL:
