any room for movements on a 24mm x 36mm sensor?
At 17mm, there is some room, but not a lot ... 3-4mm, max:
The coverage is about the same at 18mm, but starts increasing at 19mm, where there's ~4-5mm of movement available.
FYI, here's a test photo I took at 17mm, with ~3mm of rise, of a house down the street, using the A7R as a back:
As you can see, there's some darkening of the upper corners starting, but for most photos, I can live with it. (Of course, for most of my nighttime photos, it's not an issue at all, what with the mostly black sky overhead and all, but YMMV.)
But there's no way it will cover a 33x44 sensor.
And for the moment, there's no way to control the electronic aperture with the lens mounted on the camera (although I'm working on that and expect to successfully transfer the guts of a Kipon adapter into my modified Toyo, where I am using a modified Contax N 26mm auto extension tube to mount the lens on a custom recessed board and a modified, generic, Sony E-mount auto extension tube to mount the body. Both of these mounts have electrical contacts built-in and use wires to connect them to the other side, so it's not a big deal to splice-in the Kipon circuitry. I actually have it all working on the bench, but because I've changed direction and am now building a smaller, lighter, custom camera around a modified Toyo Robos rear standard, I haven't bothered to install it into my existing camera. (And FYI, it's
not possible to easily use the guts of a Fringer adapter, either, because the electrical contacts on both sides are connected directly to a single circuit board, unlike the Kipon, which mounts the contacts on each side on separate circuit boards and connect them to an intermediate circuit board via ribbon cables. As such, there is no easy way to separate one side of the Fringer adapter from the other side, whereas the Kipon adapter effectively does this at the factory. Which is a shame, because I was really hoping I could use it to control the apertures of
both my Contax N and Contax 645 lenses when used with the same modified Toyo, but given my limited skill level with electronics, separate setups will be required instead. But I digress...)
